- Thank you received: 2181
LinuxCNC S-Curve Accelerations
Rod was advocating only jerk limiting X and Y as a starting point- I am saying I think that would be more work
I do see that the library does multi axes already - so that's great.
Start your frame of reference from exact path mode.
Path blending rounds corners to speed up cutting time by deviating from the exact path. It makes the road easier to go fast on - just like race cars modify the road path to be faster.
Jerk limiting allows greater acceleration settings which can lead to longer time at cruise speeds. Also programs with a lot of small moves, the machine will spend most of its time in the acceleration phases - so a higher acceleration setting can really help. - similar to good shocks and springs on our race car keeps the machine stable so one it can accelerate harder without the tires slipping. Slipping tires makers the driver have to accelerate less and so limits top speed too.
So both techniques help with overall performance.
- arvidb
- Thank you received: 158
It's a big deal for jogging, but not for path planning.so now there's a fast algorithm available which can construct an optimal trajectory between two states (pos,vel,acc) keeping the velocity, the acceleration and the jerk limited. which is kinda a big deal, as i understand.
Ruckig will happily plan a jerk-limited move between two (pos,vel,acc) states if and only if that move is physically possible. If not, it'll just say "sorry, can't do that". It won't modify an already existing, infinite jerk path. (And it won't even be able to handle all kind of jog moves out-of-the-box, which I hinted at here .)
What's needed for jerk limited trajectory planning is not an "online trajectory generator" but a planner that uses sigmoid-like moves instead of arcs when it modifies the path described by the G-code.
- Thank you received: 4153
Well if you must bring cars into it, you should watch this video which is an interesting take on some of the maths involved as we negotiate corners.Jerk limiting allows greater acceleration settings which can lead to longer time at cruise speeds. Also programs with a lot of small moves, the machine will spend most of its time in the acceleration phases - so a higher acceleration setting can really help. - similar to good shocks and springs on our race car keeps the machine stable so one it can accelerate harder without the tires slipping. Slipping tires makers the driver have to accelerate less and so limits top speed too.
But to say jerk limiting allows greater acceleration is wrong. A trapezoidal acceleration profile is planned at maximum acceleration. A jerk limited or S bend profile must violate the acceleration limits to achieve the target velocity in the same timeframe as trapezoidal.
Likewise, short segments are better understood with a trapezoidal profile. If the distance to be traversed is too short to allow room for the tool to accelerate to the desired feedrate and then deccelerate to the end point, the maximum velocity is limited so that can be achieved. This results in a triangular profile.
If a jerk limited profile is used in either case, it makes no difference whether its a short segment or a long segment, the acceleration limit must be violated.
But if you have set your maximum acceleration to a lower limit than what can be physically achieved because your machine construction cannot handle the jerk associated with trapezoidal profile (eg its has crappy suspension), then yes, you may be able to increase the maximum acceleration if jerk limited motion can be achieved. But you must ensure there is sufficient headroom to accommodate the planned acceleration which will be higher than if trapzoidal profiles were used..
But if you have set your maximum acceleration to a lower limit than what can be physically achieved because your machine construction cannot handle the jerk associated with trapezoidal profile (eg its has crappy suspension), then yes, you may be able to increase the maximum acceleration if jerk limited motion can be achieved. But you must ensure there is sufficient headroom to accommodate the planned acceleration which will be higher than if trapzoidal profiles were used.. This is exactly what i meant - one must use suboptimal acceleration if jerk limiting is not utilized.
You don't violate acceleration limits with a jerk limited planner you extend the time it takes to accelerate.
(just as you extend the time for speed changes with acceleration on a trapzoidal profile.)
but that can be offset by the fact you can set the acceleration limits higher.
I wonder if we could break out jogging planning into a HAl component just as Grotius hinted at.
I made simple_tp.comp directly from the jogging code in linuxcnc - so it would seem one could do the opposite.
that would make it easier to test back to back changes.
- Grotius
- Thank you received: 2349
It's in general a good idea to test the s-curve implementation from within a component. It will keep it simple. But then
you also need a component style gcode reader, including function's like "start from line" etc.
My current strategy after more coding today :
- Read the gcode file into a vector of paths. A path is a motion from M3 to M5. Or a rapid G0.
A path has a total motion lenght.
- The Ruckig lib will perform the motion of each path. Today i did this succesfully in a 1ms live mode.
Then during execution of the motion, parameters like acc_max, vel_max, jerk_max can be modified during the motion!
This is realy great! Also moving backwards, motion reverse is no problem.
- In the above stage's no real x,y,z interpolation is done so far. Just one DoFs is used for a lineair path planning.
Imagine arc lenght's and line lenght's combined as a total path lenght.
As a result of the above implemenation :
The tcp x,y,z and tcp euler x,y,z interpolation can be done from the position of the one DoFs.
With this result the kinematic model can be driven.
The kinematic model, for example a 6 axis robot can then use a 6 DoFs system that control's the kinematic model motion.
- Thank you received: 5334
acceleration because actual hardware cannot follow infinite jerk
profiles (because it requires instant application of force which is not
possible because of mechanical spring, motor inductance etc etc)
This is quite obvious when you tune LinuxCNC servo systems.
The largest following error typically is at the beginning and end
of acceleration so the machine acceleration often needs to be
lowered below what the drives are capable of delivering to keep
the following error within bounds.
