LinuxCNC S-Curve Accelerations
3 years 8 months ago #265340 by Grotius
Replied by Grotius on topic LinuxCNC S-Curve Accelerations
Hi Andy,
I have seen this video a few month's ago. It's interesting. Ultimate she want's to design her own spline algo.
Where you able to write some code in c or c++ for the spline example's in the video?
I have a github 3d spline repo containing a cubic spline with vel, acc profile. Maybe this is usable for background info.
This spline works excellent in opencascade, however i have no clue how to use the vel and acc of this spline output?
Today i made a github repository for the current scurve code. github scurve
Currently trying to code a 10 joint planner. 1 joint for interpolating the path, 9 joints for each motor xyzabcuvw.
If this works a bit. I will take a look at mr. Garret's comments for integrating.
3 years 8 months ago #265376 by Grotius
I got the planner running.  It has 2 buttons on the right side of the picture. The left side is unused in this example.
The path has 3 xyz waypoints, using acs (acc at start) ace (dcc at end), vo, ve.
Warning: Spoiler!
The waypoints are at the blue vertical lines.
Hmm interesting. It's interpolating over xyz now.
Next i will add scurve xyz joints to try to follow the interpolated path. Then we try to trigger a following error by
setting on of the joint's vm a little lower.
3 years 8 months ago - 3 years 8 months ago #265521 by Grotius
A little update.
Last post:
This is not happened yet. I have been thinking a while about this.
In the past i used a stepgen for this, this worked fine for my steppers.
But the stepgen is based on a linear vel system. I was thinking maybe
make a :
- scurve stepgen
- scurve pid
In the mean time, the planner is able to interpolate 3d lines and 3d arcs.
Warning: Spoiler!
To hook op lcnc, The connection to gcode input can be made now.
A converter from G2,G3 IJK to arc a waypoint is needed for the scurve planner.
This is needed because the planner uses 3d arcs, and lcnc uses planes.
Next thing on the list is try to code motion reverse, negative and positive adaptive feed.
And mdi input like goto zero etc.
The code is updated, but excedentally i deleted the readme... updated code
Last edit: 3 years 8 months ago by Grotius. Reason: removed empty spaces.
The following user(s) said Thank You: Darium
3 years 7 months ago #265955 by automata
Replied by automata on topic LinuxCNC S-Curve Accelerations
Any update on the topic? I am eagerly watching this topic and can help with development and testing if needed.
-automata
The following user(s) said Thank You: tommylight, Grotius, Darium
3 years 7 months ago #265976 by Grotius
Hi Automata,
Last day's i reviewed the  engine code. Fixed a few tiny typo's.
An sich i am quite happy with the engine code so far, i have to finish the function : process_curve(..)
This function processes the scurve scenario's.
I made the project structure a little different. It's now divided in dir's with their purpose.
Now working on a planner to look if
  • pause
  • resume
  • vm interupt
  • waypoints
  • motion reverse
will work. This code is dirty, raw and not finished,
but you can play with it already.
Yesterday i thought how to get rid of the vm sampling, to get a better interupt performance.
I made a line-line intersection of 2 scurves to get a new vm value.
Hmm, this was not going to work. This works only for full curves. Otherwise this would be perfect.
To get rid of the vm sampling, we could try to draw a spline to a few scurve points, to get a new vm value.
But then you have to find the spline y limit. This also is time consuming. If this should take 0.01 ms it's ok.
What you could check is mr. Garrets notes in this thread. Test if his notes setup works.
Check if you can do improvements or anything to the code. Maybe make a test dir in the sc_project.
You could make a hal interface, then scurvelib can be used stand alone. We need a nice readme file for github etc.
You could check this cubic spline lib. It has mutiple files. And is a 3d spline with acc and vel profile.
I don't know how to use the acc and vel results. However, the spline works perfect with opencascade.
Maybe this spline is usable for building scurve's.
3 years 7 months ago #266085 by Grotius
A little update.
Currently finalizing the planner code. A few pause, pause-resume things to solve. Most of it is working now.
I think we get this working soon.
The following user(s) said Thank You: wellingtoncsouza, Darium
Time to create page: 2.387 seconds
