- Thank you received: 134
LinuxCNC S-Curve Accelerations
- endian
1 year 7 months ago #325272
by endian
what does exactly meas "Additionally, the following libraries are required:" ... If I want to install the S-curve generator ... I will need both them install too?
[/code]
Replied by endian on topic LinuxCNC S-Curve Accelerations
Hello,Hi Endian,
link
what and which should be declared for basic workbench setup
After install, you can run it. See link how to setup and run.
DependenciesTo build and run this project, you need the following dependencies:[code]sudo apt-get install libceres-dev
- Grotius
- Thank you received: 2349
1 year 7 months ago #325278
by Grotius
Replied by Grotius on topic LinuxCNC S-Curve Accelerations
Hi Endian.
The scurve planner uses :
libclothoid3d and libscurve
libclothoid3 depends on libceres.
the scurve planner is tpmod.so.
loaded by linuxcnc.
Do you only want to use libscurve to generate motion for servo motor?
loaded by linuxcnc.
The following user(s) said Thank You: endian
- Thank you received: 4153
1 year 7 months ago #325285
Replied by rodw on topic LinuxCNC S-Curve Accelerations
I wonder if the scurve planner could not be renamed to say "stpmod.so" or even "grotius-tp.so" in the build process?
The trajectory planner is loaded in the ini file settings so the name can be anything.
Changing the name would allow it to coexist in a version of linuxcnc that also includes the default tpmod.so. This would be desirable long term.
- Thank you received: 7491
1 year 7 months ago #325287
Replied by tommylight on topic LinuxCNC S-Curve Accelerations
I agree with Rod, naming can and will cause issues as soon as more people start using this, so changing it sooner rather than later would be beneficial.
Also agree on calling it Grotius, for us who spend more time here on the forum it would obvious, and new user will have to learn whatever the name may become.
P.S.
I still have nightmares with Probe Basic and Basic Probe !!!
Naming it QtMill and QtLathe would help a lot... Sorry LCVette, i know you asked us for a name and we came up with nothing.
We already have QtDragon and QtPlasmaC, those should fit nicely in the naming scheme.
P.S.
The following user(s) said Thank You: rodw, Grotius, endian
1 year 7 months ago #325293
Well that's settled grotius-tp it is! Who wants to pick a fight with Tommy!!!!I agree with Rod, naming can and will cause issues as soon as more people start using this, so changing it sooner rather than later would be beneficial.
The following user(s) said Thank You: tommylight, Grotius, endian
1 year 7 months ago #325296
Me, every single day, all day long!!!
Time to create page: 0.385 seconds
