LinuxCNC S-Curve Accelerations
3 years 4 weeks ago #282146 by chris@cnc
Replied by chris@cnc on topic LinuxCNC S-Curve Accelerations
I have another idea to make this a little easier. How about a custom Kinematic comp. I've been thinking about it for a long time but I can't implement it. The timers for the s-curve bell should be adjustable in the ini. and then just forward it in the comp.
E.g. "pos->tran.x = (j[0] s-curve algo);"
3 years 4 weeks ago #282155 by Aciera
Replied by Aciera on topic LinuxCNC S-Curve Accelerations
Hm, not sure but basically you would be using a toolpath that has been generated on condition that the first derivative (velocity) is continuous and then you are just filtering the acceleration to make a new path that also satisfies the condition of having the second derivative continuous. Also you would be doing this in real time with zero look ahead. I don't think that is possible without considerable deviation from the part geometry but I'm no expert.
I've always though that this is a question of trajectory planning, which means: Jerk control is built into the _shape_ of the tool path like it is done in road building.
At the end of the day every toolpath run on a real machine is going to be jerk limited because no drive chain can accelerate instantly but if the toolpath has not been calculated with this in mind then there are going to be geometric errors because of this.
The following user(s) said Thank You: chris@cnc
3 years 4 weeks ago #282157 by Aciera
Mayor issue was that lcnc is running out of cyclus time. The different algo's take to much.
Note there is a thread about moving the trajectory planner to non-real time which may be of interest (If I recall correctly the code itself was unfortunately not shared):
forum.linuxcnc.org/38-general-linuxcnc-q...time?start=10#263611
3 years 4 weeks ago - 3 years 4 weeks ago #282177 by Beef
Replied by Beef on topic LinuxCNC S-Curve Accelerations
@Grotius It's great to hear from you!
So I haven't been able to make much progress in the interim - I have competing demands with work and this is still a side-project for me. Not to mention it's a super complex problem to wrap your head around. To be honest I have absolutely no idea how you wrapped your head around it so quickly - I had a lot of respect for your work just reading the forum posts, and now that I see it firsthand I'm even more impressed with what you got working .
I was able to compile your existing code and get it to run but I wanted to be able to incorporate it into the existing LinuxCNC build system and make some changes to use a compiled Ruckig lib instead of the semi-custom library it appears you made.
The reason I want to try and use the compiled lib is that I also reached out to the Ruckig guys to see if they are willing to sell licenses for individuals/hobby use. I don't believe that the lookahead function will work without either some hacky workarounds such as adding extra axes and performing calculations incorporating those, so knowing whether or not this is an option would likely be helpful. I assume they will distribute precompiled binaries or something to that effect, which is why I want to try and rely on a compiled lib.
If they aren't willing to do individual licenses and there isn't a reliable way to make the lookahead function work, I may end up ditching the ruckig lib entirely and trying to incorporate one of the 3d printer S-curve trajectory planners instead to get it working for 3 axis stuff at least.
Last edit: 3 years 4 weeks ago by Beef.
3 years 4 weeks ago #282183 by chris@cnc
 You are definitely more of an expert than me. And yes, we have an error in the geometry. But it depends very much on the time set. If you draw a straight line to the acceleration curve, the distance is the error. The question now is: do we always need a perfect system? Not in rapid feed and not in jog.
The idea of integrating trajectory planning into an S-curve is as ingenious as it is difficult. And great respect to try solving that. My idea was perhaps to approach the problem in small steps. Maybe then we can see whether the whole thing can be solved differently so that it isn't so complex.
3 years 4 weeks ago #282191 by Grotius
Replied by Grotius on topic LinuxCNC S-Curve Accelerations
Hi all again,
The cmake project of my linuxcnc fork : github.com/grotius-cnc/linuxcnc/tree/main/cmake is still compiling.
I started the axis gui, scurve config by executing the runtest in directory : github.com/grotius-cnc/linuxcnc/blob/mai...onents/sc_tp/runtest
This is starting a axis gui, performing the scurve motion along the linuxcnc start screen letters.
An sich this works, but code is not finished.  From here i could give it a fresh new try.
The following user(s) said Thank You: pommen, chris@cnc
Time to create page: 0.484 seconds
