- Thank you received: 7491
They are enabled when installed and fully functioning.Though "included" ≠ "enabled"
@Rodw,
Thank you for your effort, all your input so far.
I have tried to create a .iso for day's, using the lb build system and also by using a chroot environment.
However it failed at some point when the .iso installation was ~60% complete.
Also the linuxcnc live build failed at some point, it had something todo with filmware, but that's no problem.
Then creating .deb packages is also a lot off work. As you have at least 2 types. The normal packages and the -dev packages
wich includes .headers etc.
I think we have to use 3 types, like the normal, the -dev and the -source.
For now i use a Qemu vm. Install debian and the software we need. Then the Qemu .img file can be compressed and
downloaded by others to test in their vm.
For running on real machines, i have to do a extra conversion step from .img to other .img type,
then write the .img to usb, and it will run.
