- Thank you received: 2349
I will check it in my virtual machine and let you know but the best path will be to wait for your iso file because of all the components and stuff around ...@Endian,
I am not ready with the .iso, but you can try this archive. Unpack it where you want.
Then : ./install.sh
I didn't test it on a fresh .iso so i can not confirm it works straight away.
After installing goto : ~/linuxcnc/cmake/configs and do : ./run_axis_9
At your own risk:
repository.qtpyvcp.com/repo/linux-distro/lcnc_archive.tar
