LinuxCNC S-Curve Accelerations
1 year 6 months ago #326088 by Grotius
Hi all,
For info.
The distro is updated to use Debian 13 and linuxcnc scurve + ethercat.
There where some problems to get ethercat running on linuxcnc, these are now solved.
repository.qtpyvcp.com/repo/linux-distro/
The debian-disk.img.7z is to use directly in qemu vm.
The debian-raw.img.7z is to be copied to usb.
The following user(s) said Thank You: akb1212, tommylight, HalaszAttila, rodw, endian, Darium, zmrdko, Unlogic
1 year 6 months ago #326351 by Grotius
the latency debian 13 is very bad.
We have to come up with an idea to
solve this.
1 year 6 months ago #326362 by rodw
Replied by rodw on topic LinuxCNC S-Curve Accelerations
solve this.
Latency or network latency?
1 year 6 months ago #326377 by Grotius
HI Rod,
A tester send me this :
Debian 10 : jitter max 45200
Debian 12:jitter max 29000
Debian13:jitter max 522000
Ir looks very bad.
1 year 6 months ago #326385 by tommylight
Debian 13 does not seem to be using an RT kernel, based on the numbers, but it just might be, i know i had worse on a new PC back in 2020, with RT kernel it would not do anything under 6000000 (yes 6 million).
That was an outlier as i have used over 50 PC and laptop from then, but never that terrible.
I do have a Dell laptop that does that, even with RTAI kernel, if anyone is interested. :)
1 year 6 months ago #326388 by Grotius
The used kernen in debian 13 :
linux-image-6.12.21-rt-amd64
I havent done the latency myself so far.
For the tester i will make a debian 10 with his current kernel.
But somehow we need a better kernel for debian 13. This looks not usable at all.
Time to create page: 0.092 seconds
