How do I get Linux cnc out of E-Stop?
- royKO1405
27 Nov 2017 22:44 #102407
by royKO1405
Replied by royKO1405 on topic How do I get Linux cnc out of E-Stop?
Hi Andy
I am pleased that you couldn't do it, I was beginning to think that Linux had put a curse on me. I am new to coding; what is the command string to format my C drive?
Best regards
Roy
Best regards
Roy
28 Nov 2017 00:32 #102416
Replied by andypugh on topic How do I get Linux cnc out of E-Stop?
I just tried booting a VM from the liveCD. This seems to work.
1) Check what the HD is called, and make sure it is the right size.
Commandoutput
So that tells us that the disc is called "sda". Yours might be different.
Now format it
Commandoutput
Command
sudo fdisk -lDisk /dev/sda: 21.5 GB, 21474836480 bytes
255 heads, 63 sectors/track, 2610 cylinders, total 41943040 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
Disk /dev/sda doesn't contain a valid partition tableSo that tells us that the disc is called "sda". Yours might be different.
Now format it
Command
sudo mkfs /dev/sdamke2fs 1.42.5 (29-Jul-2012)
/dev/sda is entire device, not just one partition!
Proceed anyway? (y,n) y
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=0 blocks, Stripe width=0 blocks
1310720 inodes, 5242880 blocks
262144 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=0
160 block groups
32768 blocks per group, 32768 fragments per group
8192 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000
Allocating group tables: done
Writing inode tables: done
Writing superblocks and filesystem accounting information: done
The following user(s) said Thank You: royKO1405
- royKO1405
28 Nov 2017 00:45 #102418
by royKO1405
Thanks for the link Andy I will give it a try in the morning.
Time to create page: 0.107 seconds
