Orient, modes 1 and 2 work, cannot do mode 0
- raglanlittlejohn
- Thank you received: 9
20 Jan 2018 04:33 #104740
by raglanlittlejohn
Orient, modes 1 and 2 work, cannot do mode 0 was created by raglanlittlejohn
I'm using orient as shown in this schematic. I can get it to work ok turning the spindle by hand,(I'm waiting for a new vfd which should run the motor slow enough to stop in position).
I cannot get it to work in mode 0. This is were it turns the spindle to the commanded position, cw or ccw, whichever is closest.
I think it will be quite usable in mode 1 only, but am interested to know if theres something wrong with the way I've set it up.
21 Jan 2018 05:11 #104770
Replied by andypugh on topic Orient, modes 1 and 2 work, cannot do mode 0
This might not be the problem, but you are passing a degrees value to motion.spindle-revs, and that needs to be a 1-per-rev signal.
Note that the orient component does scaling. It expects a 0 to 360 input for the angle, but a 0 to 1 input elsewhere and has a 0 to 1 output.
The following user(s) said Thank You: raglanlittlejohn
- raglanlittlejohn
22 Jan 2018 14:30 #104866
by raglanlittlejohn
Replied by raglanlittlejohn on topic Orient, modes 1 and 2 work, cannot do mode 0
With Andy's advice, I've managed to get the orient to work in all three modes. I would also like to get the spindle position to reset to zero on an encoder index pulse, prior to running M19. I know this has been done before using a mux4 component, but am not sure how this was done.
23 Jan 2018 06:46 #104887
I think the neatest way to home the spindle to index (which might be very useful in cases where the spindle can spin faster than the counter can manage, which need not necessarily preclude spindle-synched motion up to a limted speed) would be to add the orient component to the index-enable net.
I can imagine adding a parameter "index-delta" that is added to the current position command output in order to force the spindle to spin until the index is found.
- raglanlittlejohn
23 Jan 2018 12:25 #104908
by raglanlittlejohn
Andy, out of interest, would a G76 sequence sync up the index, so that M19 would work correctly?.
- raglanlittlejohn
23 Jan 2018 16:07 #104923
by raglanlittlejohn
Andy, please could you explain how to add the orient component to the index-enable net. Is the index-enable net
something like net spindle-index-enable hm2_5i25.0.encoder.02.index-enable <=> motion.spindle-index-enable.
When you say 'add the orient component', do you mean one of its pins is to be added?.
Sorry to be a pain, but I think I've nearly got it working now, and looking forward to trying it on my new vfd when it turns up.
24 Jan 2018 01:16 #104931
I was suggesting modifications to orient.comp to allow this.
I get home from Lapland tonight, I might have a look into this.
- raglanlittlejohn
03 Feb 2018 16:15 #105375
by raglanlittlejohn
I've used classicladder and a pyvcp panel to 'home' the spindle. All working well now. Thanks again to Andy Pugh for your advice on setting up the encoder etc.
- Mike_Eitel
- Thank you received: 183
04 Feb 2018 02:52 #105391
by Mike_Eitel
Replied by Mike_Eitel on topic Orient, modes 1 and 2 work, cannot do mode 0
Hi Andy
Have you seen and touched some reindeer?
Very nice experience!
Time to create page: 0.792 seconds
