3D printer with multiple extruders
8 years 8 months ago #106154 by RichJordan
Grotius,
I do need to store positions for each extruder. I hope to call a tool change (Tx M6) and then extrude using G1 Ax.xx, call another tool change and then extrude on a different extruder with the same G1 Ax.xx command.
8 years 8 months ago #106156 by RichJordan
Rodw and tommylight, thanks for your feedback/ideas, I have searched for the multi spindle work and found this post which looks promising:
forum.linuxcnc.org/10-advanced-configura...thon-lessons-learned
I have a lot of learning to do so links to documentation that will be helpful such as how to remap stepgen outputs on an M6 would appreciated.
8 years 8 months ago #106158 by rodw
I know nothing about the tool changer side of things.
If you have a look through your hal file, you will see that there are some axis.A.xxxx signals mapped to stepgen.N signals. So your goal is to change those mappings to a different stepgen number. There are probably other ways but I think if I were doing it, I would write a component that received a 1,2,3 to select your extruder number and select the correct stepgen. If you wanted to select the extruder from gcode, M68 would do the job nicely. Then roll it all up into a toolchanger that knows the extruder offsets.
I'd have to think it through a bit but as inputs, you probably would have the selector pin and a set of Axis.A pins. and as outputs you would have 3 sets of stepgen signals. Then you just copy the inputs to the correct set of outputs that point to the stepgens. There may also need to be a feedback signal from the stepgens back to axis.A to complete the loop.
8 years 8 months ago #106727 by andypugh
Can any of the slicers output the extrusion feed in incremental rather than absolute mode? That would make things much simpler.
8 years 8 months ago #106738 by Mike_Eitel
I think you should have s look into marlin. They have solved quite a lot and a slicers like simplify3d and cura etc. have quite an uniform way to produce G code for multimaterial.
Time to create page: 0.149 seconds
