Simulator
8 years 8 months ago - 8 years 8 months ago #106755 by Grotius
Replied by Grotius on topic Simulator
@Techno,
You error has to do with a picture of a button. Can you add a picture to the button in glade? Or maybe in glade delete the button image related traceback?
Do you have a .glade file of your actual screen loaded?
For the rest your error is located in the usr ... bin... glade file, when this is happening, you can not solve this there.
So it's a quite simple problem, but has to solve in the top of the program... somewhere in glade or somewhere in your current used files.
I think you don't have to search in the python files first. I preferr to solve it in the glade file's if possible.
Last edit: 8 years 8 months ago by Grotius.
8 years 8 months ago #106758 by tecno
Replied by tecno on topic Simulator
I was hoping for a straight forward install of Lathe Macros just following instructions of what to copy where.
Do not know anything glade etc...
8 years 8 months ago - 8 years 8 months ago #106760 by Grotius
Hi Techno,
Okey thanks, the error report is for me too difficult too solve with macro instructionÅ› or command line instructionÅ›, sorry for that.
Maybe Todd can do something with teamviewer with you to solve the problem... Idea?
In your ini file i see a suspected item B) :
EMBED_TAB_COMMAND=halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -u lathehandler.py -x {XID} lathemacro.ui
Why a double "gladevcp gladevcp"? :woohoo:
My logic tab line idea would be :
EMBED_TAB_COMMAND=halcmd loadusr -Wn gladevcp -c gladevcp -u lathehandler.py -x {XID} lathemacro.ui
This is logic without looking ad the meaning of the code that is written... Double loading makeÅ› most of time no sense.
8 years 7 months ago #106835 by tecno
This comes from README file in LatheMacro-3.zip
This config demonstrates the Lathe macros described here:
www.linuxcnc.org/index.php/english/forum...s/26550-lathe-macros
To add the macros to your own config you need to add this line to the INI file [DISPLAY] section:
[DISPLAY]
EMBED_TAB_NAME=Cycles
Then put these files in the same directory as the INI file.
boring.ngc
chamfer.ngc
facing.ngc
radius.ngc
threading.ngc
turning.ngc
lathehandler.py
lathemacro.ui
If I edit and erase that gladevcp LCNC will not start! So there must be something else that is wrong here.
8 years 7 months ago #106847 by tecno
Hmmm.
Bloody confusing this is = 3 zip files
managed to get the PLAY button installing svg files from TOUCH zip
But now error message
EOF in file:/usr/share/axis/images/axis-lathe.ngc
seeking o-word: o<facing or whatever task you want to do> from line: 0
So where can I find the correct axis-lathe.ngc so that I can start playing around with these macros?
8 years 7 months ago #106917 by tecno
Problem solved = does not work with 2.7
The following user(s) said Thank You: Gerald
Time to create page: 1.197 seconds
