lube alarm broken on last update
- OT-CNC
- Thank you received: 75
24 Mar 2019 02:24 #129429
by OT-CNC
Replied by OT-CNC on topic lube alarm broken on last update
Input is on this:
net low-lube-level iocontrol.0.lube_level lube_level.trigger <= hm2_5i25.0.7i77.0.0.input-13-not
- Thank you received: 4652
24 Mar 2019 11:23 #129466
Replied by andypugh on topic lube alarm broken on last update
Where is the message component (are you using the message component?) in the thread order?
Does it potentially run once before the first cycle of the 5i25 read thread?
- OT-CNC
24 Mar 2019 15:02 - 24 Mar 2019 15:11 #129476
by OT-CNC
I don't think I'm using any threads. I just have the messages listed in the beginning of the hal file.
loadrt message names=lube_level messages="LOW LUBE"
then below is:
addf hm2_5i25.0.read servo-thread
followed by:
addf lube_level servo-thread
# --- OIL-LEVEL ---
setp lube_level.edge 0
then below is:
followed by:
# --- OIL-LEVEL ---
Last edit: 24 Mar 2019 15:11 by OT-CNC. Reason: added the 5i25 read and order of listing
24 Mar 2019 15:20 #129479
"addf" adds the function to a realtime thread.
If it is added earlier in the HAL sequence than the 5i25 read function then it will run once before the 5i25 pins have done their first update.
- OT-CNC
24 Mar 2019 15:30 #129480
by OT-CNC
I'll swap it around and see if it makes a difference. Thanks for the pointers.
- pl7i92
- Thank you received: 358
24 Mar 2019 16:18 #129482
by pl7i92
Replied by pl7i92 on topic lube alarm broken on last update
you also can use a AND
so if Estop is off it calls the function or puts out the mesage
not only on Initalisation
- Thank you received: 5321
24 Mar 2019 16:19 #129483
Replied by PCW on topic lube alarm broken on last update
If its some kind of start up glitch it might be a good idea to mask the input until LinuxCNC is in the "Machine-On" state
- OT-CNC
24 Mar 2019 16:31 - 24 Mar 2019 16:31 #129488
by OT-CNC
This does come on before machine is in the on state.
How do I mask the input? I don't really want to try adding to the estop logic. I'll just end up breaking it further lol...
Last edit: 24 Mar 2019 16:31 by OT-CNC. Reason: sp.
24 Mar 2019 16:39 - 24 Mar 2019 16:40 #129490
If you chose the correct 7i77 pin for active high alarm (high meaning low-lube)
you would use an "and" component with one input connected to machine-on and
the other to the 7i77 input pin.
The output of the and component would connect to the (active high) trigger on
the message (you would need to set the message trigger to active high)
Last edit: 24 Mar 2019 16:40 by PCW.
24 Mar 2019 17:29 #129494
To elaborate, there is a HAL pin called "halui.machine.is-on" and you can use this to mask the low-lube warning until the machine is turned on.
Time to create page: 0.282 seconds
