Newbie question
22 Mar 2018 09:33 #107722 by schaet
Newbie question was created by schaet
Hello,
I am a total newbie here feeling my through. I tried running my first program and got the following error:
"Cannot feed with zero spindle speed in feed per rev mode"
Can anyone shed some light on this? I'm sure it's a simple setting I have wrong
Attached is my g-code
File Name: Trijiconv4-2.nc.txt
File Size:42 KB
Thank you
Steven
My setup:
Sherline 5400 CNC
LinuxCNC
BobCAD/CAM with the Sherline post processor
22 Mar 2018 10:13 - 22 Mar 2018 10:26 #107725 by DanMN
Replied by DanMN on topic Newbie question
I'm presuming you start your spindle manually, i.e., not via gcode -- since you only have M0 specified -- which is spindle stop. In essence, the you are instructing the machine to plunge cutter that isn't spinning. Obviously, in systems that have spindle control automated this would be a big no-no.
Try adding an M3 statement here:
(MSG, " Spindle Speed 1191")
(M0)
M3 S1 F1
Touch off your Z well above your table or workpiece for a dry run. Let the spindle cut some air while you observe the behavior and become comfortable with the new instructions. I always test creative new ideas with my hand on the e-stop button ;)
PS: I just modified and loaded your file, and you have other problems -- namely that line 11 command being a country mile long and obviously weird. I changed the Y value to 133 and it loaded, but with some expected problems with scale. It looks like you're cutting a postage stamp size object on a billiard table -- so, you've got some CAM setup issues to work out as well.
Last edit: 22 Mar 2018 10:26 by DanMN. Reason: Added observation..
22 Mar 2018 13:56 #107730 by schaet
Replied by schaet on topic Newbie question
DanMN,
Thanks for the info. I'll check it out when I get home tonight.
Any ideas what to look for with the CAM setup? Maybe I'll re-create the job and do a stare and compare with the two posts.
Also, what was it that you saw that showed you that the scale was off?
Thanks again!
22 Mar 2018 16:18 #107738 by DanMN
My comment on the scale was due to this picture -- notice your part is that tiny tool path in white, and for some reason your are getting gcode that tells you your toolpath includes a point 133 inches north in empty space. I don't have any explanation for that, but your original line 11 had a Y value that required a line wrap on my wide screen monitor -- I gave up looking after a few dozen digits. That's the value I shortened from 133 bazillion to just 133.
22 Mar 2018 16:29 #107739 by JohnnyCNC
Replied by JohnnyCNC on topic Newbie question
You might try G94 instead of G95 along with what DanMN said. M0 is program pause. I'm new at this also so trust but verify. Good Luck John
G94 - is Units per Minute Mode. In units per minute feed mode, an F word is interpreted to mean the controlled point should move at a certain number of inches per minute, millimeters per minute, or degrees per minute, depending upon what length units are being used and which axis or axes are moving.
G95 - is Units per Revolution Mode In units per revolution mode, an F word is interpreted to mean the controlled point should move a certain number of inches per revolution of the spindle, depending on what length units are being used and which axis or axes are moving. G95 is not suitable for threading, for threading use G33 or G76. G95 requires that motion.spindle-speed-in to be connected.
M0 - pause a running program temporarily. LinuxCNC remains in the Auto Mode so MDI and other manual actions are not enabled. Pressing the cycle start button will restart the program at the following line.
(TRIJICONV4-2.NC)
G17 G20 G95 G40 G49 G80 G90 G00 X0 Y0 Z0
(MSG, " Change to .25 ENDMILL ROUGH")
(M0)
G43 G90 H1
G1 Z1. F5
(M0)
(Begin Feature 3 Axis)
22 Mar 2018 18:07 #107741 by JohnnyCNC
I changed the G95 to G94 and line 14 Y1333... to Y2 and Z2 to Z1 so it didn't exceed the bounds of my machine and the code will run.
( tool 1 ENDMILL ROUGH D.25 C0. L2.5)
(TRIJICONV4-2.NC)
G17 G20 G94 G40 G49 G80 G90 G00 X0 Y0 Z0
(M0)
G43 G90 H1
G1 Z1. F5
(M0)
G0 X0. Y2 Z.1
22 Mar 2018 19:42 #107742 by schaet
JohnnyCNC and DanMN
Thank you for the input!! You guys rock! I was able to load the file and I ran the program (without the mill attached) and it looks good. I'll try it tomorrow on some stock and see how it looks.
So much to learn here ..
I'll let you know how I make out.
26 Mar 2018 08:31 #107898 by schaet
Well I made some good progress last night. I was able to run the program with decent results.
I made the above suggested changes, but in addition to that I took out the line: G43 G90 H1. It was starting my Z axis at .050 above my stock. After researching it appears to do with my offset setting. I'll have to figure that out with my software and correct that.
The only other issue I see is that the cutting dimensions are a little off. That may have to do with my mill, but I don't know yet.
Thanks again for the help!
26 Mar 2018 09:33 #107903 by DanMN
Good to hear you are making progress. You can play with the SCALE variable for each axis first and see if that corrects dimension inaccuracies. Then you can look at backlash compensation, machine rigidity, etc.
Have fun. Don't crash it ;)
27 Mar 2018 11:26 #107961 by andypugh
Replied by andypugh on topic Newbie question
Most CAM packages assume that absolute 0 for the Z axis is right at the top. That means that the home position tends to be 0, max limit 0 and min limit some-negative-number.
Actually HOME is probably -0.05 and HOME_OFFSET +0.05 or similar arrangement.
Time to create page: 1.071 seconds
