Zenbot/Gecko/LinuxCNC?
8 years 7 months ago #107989 by jandyman
Replied by jandyman on topic Zenbot/Gecko/LinuxCNC?
I'll be getting in touch with the MachineKit guys, but would it be safe to assume that their PRU step generator drivers will work with LinuxCNC, even they are not included with LinuxCNC?
The BBB solution is looking very attractive to me, so I'll investigate it. I've already got the BBB, so the cost to me is zero, and not needing a Mesa I can just explore that for the price of my own time. I've been down the Linux open source road before, so I know that success is far from guaranteed. But it is worth a little time. If it works it will be slick, even if it is not good for any realtime visualization of machine paths.
I'll report back or have more questions, but for the time being I'll head off to the MachineKit forum.
8 years 7 months ago - 8 years 7 months ago #108070 by jandyman
I've been over to the MachineKit forum, and that option is not looking attractive, mostly because the PRU pins apparently cannot interface directly with my Gecko, so I'd have to build some sort of interface. It's certainly something I could do, but my project time needs to go into what I can do with my CNC, not my CNC itself.
Also everyone seems to think I should still have an external PC because of "the graphics". I'm still confused about why that is an issue, but sometimes it is good to listen to people.
If I need an external PC or an embedded board that isn't much cheaper, then I want to interface with my CNC with ethernet or USB because it is more flexible. But seems to be exactly where LinuxCNC seems to be weak.
Wouldn't it be nice if I could get a Chromebook, convert to linux and the hook up to the PC with one of these?:
www.amazon.com/Parallel-CNC-Motion-Contr...icense/dp/B07692WLB7
Alas, it is sounding more and more like a "can't get there from here" situation. At least not easily. I may have to tolerate Windows, run UCCNC, buy one of the above and be done with it. Maybe LinuxCNC will be more USB and ethernet friendly down the line a bit.
Does that make sense?
Last edit: 8 years 7 months ago by jandyman.
8 years 7 months ago #108073 by andypugh
Replied by andypugh on topic Zenbot/Gecko/LinuxCNC?
USB will almost certainly never work with LinuxCNC (I would discount the possibility completely except that there was some work done on a realtime USB driver many years ago. I don't know if it ever worked.)
But Ethernet is already an option. However you need something at the other end to interface between ethernet and the stepper driver. If you are set on using the BBB then you need to find a BBB-compatible kernel with the preempt-rt patch.
I don't know what realtime patch Machinekit are using, but I would think that it was worth trying this image here:
elinux.org/Beagleboard:BeagleBoneBlack_D...l_Revs.29_Machinekit
Then open a command prompt and try:
halrun loadrt hostmot2 loadrt hm2_eth
and see what happens.
hm2_eth (the driver for Mesa ethernet boards) ships with Machinekit, so I would say the chances are pretty good that it works with their images (You could, of course, ask them).
To be honest I don't 100% understand the Machinekit philosophy of having a BBB for realtime and a second PC / SBC for the UI and graphics.
But if you are looking at a PC running Windows and adding a $165 UC100 to it, then surely a PC running Linux and adding a $90 Mesa 7i92 makes even more sense? You get a better solution and save about $200 for Windows and $100 for the Mach3 license on top of the hardware saving.
Or is the plan to run Windows on the BBB?
8 years 7 months ago - 8 years 7 months ago #108076 by jandyman
Indeed, if I had another PC sitting around to put Linux on, it would make sense to try the Mesa solution, and I think I'll look around for one. I may be able to find an old one for free, and I still really like the idea.
But I already have a laptop running Windows next to my CNC, and I'm kinda afraid of converting it to Linux, because of all the funny drivers that you typically need for a laptop. Maybe Linux is better about that these days, or I could do a live boot from a USB drive. That especially is worth considering.
I don't get why I would use MachineKit with a 7i92. Why wouldn't I just use the latest LinuxCNC and make sure I have the right kernel?
The most interesting part of your reply is your comment about having "a better solution". Do you say that because it is Linux or because you think the LinuxCNC experience is superior to the UUCNC software experience? If the latter, that is additional motivation to consider LinuxCNC.
I started thinking about USB because of the Chromebook option, but more and more laptops especially don't even have ethernet ports anymore.
8 years 7 months ago #108079 by andypugh
jandyman wrote: I don't get why I would use MachineKit with a 7i92. Why wouldn't I just use the latest LinuxCNC and make sure I have the right kernel?
If you are happy to do that, then yes, that is an option. I was only suggesting Machinekit as a way to get a precompiled kernel (and I don't even know what kernel they use)
I am not sure that the experience is better, but I am fairly confident that the technical capabilities of LinuxCNC are likely to be better. By having the motion controller in the PC you can watch what it is doing, and reconfigure in interesting ways. For example it is only a few lines of HAL connections to convert a milling machine into a gear hobber. I doubt that UUCNC can do that. Does it even offer rigid-tapping or lathe thread cutting?
8 years 7 months ago #108084 by rodw
Replied by rodw on topic Zenbot/Gecko/LinuxCNC?
When I was looking at a platform for a CNC machine with no knowledge of anything, despite having a mate who loves in the same street that has 2 Mach3 machines willing to help me, I could not bring myself to use it. It was old, there were few PCs still around that had parallel ports and the whole Break out board system seemed to be very limiting. So there were no compelling reasons to purchase obsolete software that was not going to run on current hardware.
LinuxCNC seemed to be the most logical choice due to the lack of real time support in Windows that required expensive hardware (eg. smoothstepper) to work around. Even then the performance is only 1/3 of what can be achieved with Mesa hardware. I ended up purchasing a Mesa 7i76e ethernet card. For a PC, I am using a Gigabyte J1900 USFF PC which cost AUD $100, the same as a Beaglebone Black. Another $100 for the smallest memory chip I could purchase (4gb) and a 120 Gb SSD and I have a perfect platform about 5" square that is attached to the back of my touch screen monitor. Whilst this is a perfect solution for me, I also do like Andy's approach of treating a small PC Motherboard as just another component to wire up in the control panel.
I will say it was hard to get the prempt_rt kernel installed but the guys here helped me all of the way. Now there is an excellent tutorial on the forum here and also now a preempt_rt ISO image that you can use so its even easier again.
I'm a fan of Arduinos, Blackberry's and the like but, they have too many limitations for CNC work. Once you get you get your head around Linuxcnc's HAL files (which should be pretty easy for you as you can migrate your mach config.) it is a rich environment.
In my view, LinuxCNC's real strength is the ability to extend the system by writing HAL components in C and installing them in seconds to extend the HAL environment.
Finally those on this forum I've seen make the switch from Mach/Windows to LinuxCNC are well pleased with the decision and their satisfaction seems even greater where they've used Mesa in the mix.
Time to create page: 0.837 seconds
