Zenbot/Gecko/LinuxCNC?
8 years 7 months ago #108154 by andypugh
Replied by andypugh on topic Zenbot/Gecko/LinuxCNC?
jandyman wrote: Excellent. I'll do just that. I did find the Mesa configuration wizard but it said is was beta and I shouldn't count on it. (Out of date documentation?). .
More a fear of over-promising on a bit of software that can never be tested on all possible hardware.
8 years 7 months ago #108155 by jandyman
Replied by jandyman on topic Zenbot/Gecko/LinuxCNC?
Just looked at Gmoccapy real quick. It looks like it does do Z autozero but not the way I want to do it. I want to put a conductive plate of known thickness on top of my stock. The router is connected to the other conductor so the bit is too. I might eventually go with something with a separate tool change block, but not yet. I certainly want both options.
8 years 7 months ago #108170 by rodw
Replied by rodw on topic Zenbot/Gecko/LinuxCNC?
Gmocappy supports a series of macro buttons. You could program one of those to do your touchoff using gcode. For the record, I believe the G38.x probe functions in Linuxcnc are superior to those on Mach. You do it something like this (from my plasma setup)
G38.2 Z-1.75 (Probe to find the surface) G0 Z[#5063 + 0.07] (Move to Probe Trip point + switch hysteresis) G92 Z0 (Set Z zero)
You'd just change the G92 to set the height you want.
8 years 7 months ago - 8 years 7 months ago #108179 by jandyman
The shoot out between LinuxCNC and UCCNC continues, with attempted test drives of either option
LinuxCNC
I downloaded the iso previously referenced iso, put it on a USB flash drive, and booted. There was list of different versions to try and boot. I tried all four RT kernel versions, because until the last one, none of them booted properly. The one that seemed to work was second in the list.
This version of Linux doesn't seem to support tap on my touchpad, within a couple minutes I had to go get an actual mouse to relieve frustation. Not a show stopper, but Ubuntu doesn't have this problem.
Fired up LinuxCNC, tried various sims. I was quite surprised that I couldn't easily find a jog window in most of them, this seems pretty basic. And the standard jog keyboard commands from Mach3 and UCCNC don't seem to work. Didn't find any easy way to figure out what they might be. So there isn't much I can do with the sim.
The Gmoccapy sim crashed, complaining about a missing module gst which is apparently needed within some python module to play sounds.
The problem with boot and the mouse means that I would want to verify that the ethernet port actually works before ordering a Mesa board. I would have to figure out how to do that.
On a positive note, I did get the sense that if Gmoccappy weren't broken, it would have a decent look on the screen, probably better than the UCCNC screens
UCCNC
Since this is a Windows program, the install is seemless, and the program came right up in demo mode. The jog keys worked and everything seems functional. No hassles.
But I really don't like the default screen. I would definitely want to buy another screenset which I could get for $25 here:
www.thecncwoodworker.com/2017.html
So that would bring the total cost of UCCNC to $159 + $67 + $25 = $250, vs. $89 for LinuxCNC
That's a little annoying, but I do have to consider my time.
I'm not giving up on LinuxCNC quite yet, maybe I'll get some help here. But so far my CNC mentor's words are ringing my ears.
Last edit: 8 years 7 months ago by jandyman.
8 years 7 months ago - 8 years 7 months ago #108181 by andypugh
jandyman wrote: Fired up LinuxCNC, tried various sims. I was quite surprised that I couldn't easily find a jog window in most of them, this seems pretty basic.
In the Axis sims the keyboard arrows do X and Y (X and Z in Lathe Mode) and page-up / page down for the Z axis.
But you do have to be on the "Manual" tab for jogging to work. (And have the machine out of e-stop and turned on)
I don't think that any of the GUIs have a separate screen for jogging.
It looks like you can't do anything at all in the Touchy sim config because Touchy needs a jogwheel and the sim won't have one.
Last edit: 8 years 7 months ago by andypugh.
8 years 7 months ago #108182 by jandyman
OK, cool. That's fine keyboard jog is plenty, and that got it working. But now how to do I zero the X axis (without issuing gcode commands manually)? I don't see zero buttons for the axes (or keyboard commands).
Also, should someone know that the Gmoccapy sim seems to be broken in the version I was able to boot? And is it normal that three out of the four options on the ISO won't boot successfully on a laptop?
Time to create page: 1.051 seconds
