Zenbot/Gecko/LinuxCNC?
- jandyman
02 Apr 2018 00:15 #108245
by jandyman
Replied by jandyman on topic Zenbot/Gecko/LinuxCNC?
I didn't md5sum the image but I doubt that is the issue. I used and identical USB thumb drive (both recent and new) to download and boot an Ubuntu image, and it works perfectly. I could try that. But in any case Gmoccapy will still be broken.
- Thank you received: 4149
02 Apr 2018 00:44 #108248
Replied by rodw on topic Zenbot/Gecko/LinuxCNC?
You are using an experimental ISO. You are so close, don't give up yet.
This thread might help
forum.linuxcnc.org/9-installing-linuxcnc...ter-2-8?limitstart=0
So from the buildbot page, there is a statement that says
This is the stanza you need to use (read the page carefully and find it):
You may be lucky and find that the ISO has been configured to access master branch but I doubt it.
You can choose to edit that file with gedit or similar (you'll need to have root privileges or use sudo) or use Synaptics..
The Synaptics package manager is used to install/uninstall programs and is a GUI wrapper around the lInux shell. Find it in your menu system. Open it and enter your root password. Search for LinuxCNC and see if there is an entry for master or version 2.8. If so you are in luck otherwise you will need to add those lines to that file referenced above either using gedit or the provided menu option in Synaptics.Then it will show.
Then follow Tommy's simple instructions in the thread above. I was stunned how easy it was to do this in synaptics and was quite gobsmacked by the smorgasboard of software available to install at the click of a button. You don't get that kind of central repository in Windows.
Despite your problems with crappy ISO's, your journey has been much easier than I experienced. I ended up compiling the PREMPT_RT kernel from source and I tried several distributions to get my hardware supported (After I had purchased the Mesa hardware). I settled on Mint which is very nice. Once I got that far, I compiled LinuxCNC from source as it was not that much more effort. But lets leave that for another day.
Then put one of these stanzas in your /etc/apt/sources.list.d/linuxcnc-buildbot.list:This is the stanza you need to use (read the page carefully and find it):
deb http://buildbot.linuxcnc.org/ stretch master-rtpreempt
deb-src http://buildbot.linuxcnc.org/ stretch master-rtpreemptYou may be lucky and find that the ISO has been configured to access master branch but I doubt it.
- Thank you received: 7478
02 Apr 2018 00:57 #108250
Replied by tommylight on topic Zenbot/Gecko/LinuxCNC?
I do not know about gmoccapy as i do not use it, but i know and i use the same image on 4 usb drives and 2 machines and i had no issues ever. It just works, always using Axis GUI.
I have only one single problem with Linuxcnc, i do not have enough time to build and configure all the machines it can easily control, and implement all the possibilities it has, i would need 70 hour days for that.
I am aware this is not useful to you, so moving on,
If you can, buy an older desktop PC if you do not already own one, install it and have a go at it. You can use that same PC for controlling the machine later on. Using laptops to control machines is not advisable due to too many power saving options. Most laptops do work, but some just do cause to much latency errors.
As for Windows vs Linux and everything that goes with them, after over 20 years of experience and working for the biggest organizations in the world as an IT hardware expert, there is nothing to compare there, windows lost that war a long time ago, it just takes some time for people to give it a try ..... and never go back to windows.
- jandyman
02 Apr 2018 21:24 #108267
by jandyman
If I want to follow rodw's instructions above, which ISO do I start with ("the ISO" referred to in the post). Also, what buildbot page has these instructions about "stanzas"?
Probably more questions to follow. The instructions are still far from clear. The thread referred to is awfully terse as well. But it may make sense once I'm sitting in front of a working base OS.
If I can get this working, I'm going to need to know how to create my own ISO from my working install. I'll be configuring all of this on my Mac in a VM. I'm not going to turf the Windows install on my CNC laptop until I get much closer to a working setup. So once I get Gmoccapy working in sim mode on the Mac VM, I need to create an ISO from that. If that is not straightfoward, I've got a problem.
02 Apr 2018 21:47 #108269
I've already given you the link to the buildbot on this post earlier in this thread. Did you look at it?
forum.linuxcnc.org/38-general-linuxcnc-q...xcnc?start=30#108237
You don't need to worry about ISOs any more as you have the right OS with a preemptive kernel installed (based on a previous post of yours)
To save your LinuxCNC configs to move to a new machine, all you need to do is to copy the ~/linuxcnc/config folder.
Creating your own ISO is not trivial and is not necessary. Leave that to the dev team.
All you have to do is to do a software upgrade in Linux. This is done with apt_get from the command line or Synaptics from the GUI.
Linux software is stored in various repositories around the world. Whilst the Linux distro you have installed will keep all of its own files on its own repository, some projects (like LinuxCNC) are not part of the distro so you need to tell your copy of Linux where to look to find LinuxCNC which is the purpose of the stanza I quoted. (stanza is the buildbot term, not mine)
02 Apr 2018 22:16 #108270
Sorry, I reread this thread and had forgotten that you were just running from the ISO without having installed Linux on a PC.
Lets start again.
The only ISO you could get to boot happened to be an experimental image. This will be good to use on real hardware with Mesa ethernet cards. However, it does not support the older v 2.7 version of gmoccappy.
For evaluation purposes, running from the USB stick, you really should be using the official V 2.7 iso on this page under the heading normal download
linuxcnc.org/docs/2.7/html/getting-start...etting-linuxcnc.html
On this version, the dependency issue will not be a problem and Gmoccapy will work fine.
As posted earlier, I think the solution to getting this to boot is to find a Windows machine, install win32diskimager, download the official ISO, rename it so it has a .IMG extension and burn to a USB stick using win32diskimager. That should boot reliably and is the way I create all of my bootable images becasue I've had so many problems getting things to boot in the past (not just Linuxcnc).
Give it a go and report back. If it fails, you really need to take your own advice and find another PC.
Lets start again.
- jandyman
02 Apr 2018 22:43 #108272
by jandyman
The first thing that happens after I install wheezy (I'm doing this first on my Mac in a VM, I'll get to real HW later) is that I'm asked whether I want to install 293 updates. Yes, no, or some of them?
02 Apr 2018 22:53 #108273
You should really use the wheezy ISO as it is a fully functional version, the stretch version has still testing in it's name that implies there may still be bugs lurking there. Also you do not need the latest version of Linuxcnc referred to as Master or 2.8, since you will be using it on a mill.
The list of builds and versions of Linuxcnc is at buildbot.linuxcnc.org
Creating an ISO from a working environment can be done in several ways, using DD ( command line, comes with every version of Linux), using "Systemback" ( easily installed, Graphical interface, very easy to use and works very well ), etc.
Using VM should be the last resort.
You can install Linux (any version) besides windows and choose at boot time what you want to use, without removing windows or loosing anything already there, but it is a bit risky as a single mistake during installation will wipe everything.
Actually, you do not need to crate an ISO at all, all it takes is to copy a single folder to have everything backed up regarding Linuxcnc and the actual folder to back up is always named Linuxcnc.
02 Apr 2018 23:06 #108274
Sorry, took me a while to write the above and did not notice the replies.
Again sorry, but i do not get why insist on installing and using VM, all of the Linuxcnc ISO images can be written to a USB stick and boot the computer from that USB, without installing anything, ever. And it will not do anything to already existing windows installation, it will not affect it in any way.
You can boot from the USB, make a new config, edit any existing config, test anything and everything, save anything you like to another USB ( you can save to the existing hard drive, or to the USB used to boot but it takes a bit of know how ).
When booting from the USB, choose LIVE.
- jandyman
02 Apr 2018 23:28 #108275
by jandyman
Didn't know you could modify a configuration and save back to a USB stick and have that new USB be bootable. Is it obvious how to do that?
And in any case, what about the 293 potential updates to the wheezy from the Getting Started page?
Time to create page: 1.692 seconds
