Okay well, I'm officially an idiot. I went through the process of designing my entire ui just to have it not load. I can load it with gladevcp from the command line but there are tabs missing when I do it this way. I went back to the page you reference and worked through the little example that they give to make sure I didn't miss something. Problem is that it won't load either. It gives me two errors, the first:
Gscreen encountered an error. The following information may be useful in troubleshooting:
File "/usr/bin/gscreen", line 1345, in on_feed_hold_changed
self.widgets.hal_toggleaction_pause.set_active(h["feed-hold"])
File "/usr/bin/gscreen", line 185, in __getattr__
if r is None: raise AttributeError, "No widget %r" % attr
AttributeError: No widget 'hal_toggleaction_pause'
and the second:
File "/usr/bin/gscreen", line 3688, in <module>
app = Gscreen()
File "/usr/bin/gscreen", line 723, in __init__
self.initialize_widgets()
File "/usr/bin/gscreen", line 829, in initialize_widgets
self.init_dynamic_tabs()
File "/usr/bin/gscreen", line 901, in init_dynamic_tabs
self.set_dynamic_tabs()
File "/usr/bin/gscreen", line 2892, in set_dynamic_tabs
nb = self.widgets[name]
File "/usr/bin/gscreen", line 189, in __getitem__
if r is None: raise IndexError, "No widget %r" % attr
IndexError: No widget 'vcp_box'
Any ideas? I know its something silly that I over looked.
