Hurco Hawk 5M Retrofit w/ existing motors
8 years 6 months ago #109024 by biqut2
Well, I got a set of schematics from a very helpful gentleman at Hurco that has allowed me to finish the wiring on the servos and their controllers. Everything on the hardware side is ready for a bench test, I've got everything wired to Encoder 0 on TB3 and Driver 0 on TB5. I just can't make heads nor tails of the pncconf names for the pins. I'm stuck on this step: linuxcnc.org/docs/html/config/pncconf.html#_mesa_i_o_setup
8 years 6 months ago #109025 by PCW
When you start pncconf and get to the "Mesa Card 0" page, select:
"5i25-Internal Data"
and
"7i77x2 With One 7i77"
and then
"Accept Component Changes"
And the pin names should make more sense
8 years 6 months ago - 8 years 6 months ago #109026 by biqut2
Thank you very much for the fast reply. That's what I had done. on i/o connector 3 tab, I have Muxed Enc 0 set to X Encoder but I have no idea what X HALL and X Grey are. It keeps telling me to configure pwm or stepper signals.
Edit: Nevermind It wasn't showing all the pins because I told it I only had one encoder and one drive, it shows up now. I'm on the open loop test now trying to get it to move the servo.
Last edit: 8 years 6 months ago by biqut2.
8 years 6 months ago #109027 by PCW
Your picture showed that you have the wrong card and firmware selected (5I20 and SVST4_8)
did you skip the "Accept Component Changes" step?
8 years 6 months ago #109028 by biqut2
that link just points to the linuxcnc documentation page that I was working through to get this up and going. I have the 5i25 and 7i77 with the 7i77x2 firmware installed and verified. I can use the cli to toggle the LEDs on the card so I know I am communicating with it. I went back and made sure I clicked Accept Componet Changes which gives me a connector 2, connector 3, 7i77i/o, and 7i77 pwm tab. I selected the encoder and output. Still not getting any movement though, I'm completely lost at this point. I was trying to follow the documentation to avoid asking so many questions but I'm stuck.
8 years 6 months ago - 8 years 6 months ago #109029 by PCW
Before even connecting the 7I77 I would verify that you can move the motors with a 1.5V battery
(with the drives enabled) If this doesn't work you need to find out why before proceeding
Last edit: 8 years 6 months ago by PCW.
Time to create page: 0.424 seconds
