cncn00b2018 wrote: Hey,
I glanced over the list of hardware on this site listing real-time compatible gear.
While I've even seen a Pentium II in there, I kinda doubt that current Ubuntu or Debian releases will run well on that alone, much less something like LinuxCNC on top, right?
I have a few old (parts of) PCs with LPT ports, none of which are ready to go as is.
So I wonder if any of those is worth repairing.
- Duron 600 (Nice aspect is: 230W PSU. Needs most repair, though)
- Athlon XP @ 1250MHz (can't boot from USB stick, takes some effort to get around)
- AMD64, 2 GHz (without case. *maybe* fits into one of the other 2 cases... Eats more power than the other options. (still significant compared to my small Chinese CNC router))
The most obvious seeming choice would be to use the most powerful CPU (if it actually passes the real-time test).
But maybe I'm wrong, maybe the older stuff is just fine, or even better with real-time for some reason (simpler, less fancy stuff on board?).
You tell me!
