Hi
- wodji
01 May 2018 23:42 #109974
by wodji
Hi was created by wodji
Hi
I'm new and I got quick question.
I'm looking for solution of my project: My machine will be cutting same shape but many times depending of length of material only along one axis. What is the best software or solution? operator should put only length of material and rest should do software divide how many cuts and spaces etc.
Thank You
Thank You
01 May 2018 23:45 #109977
Replied by andypugh on topic Hi
What do you want the software to do? LinuxCNC can control the machine. Are you asking what you would use to provide input to LinuxCNC?
Are you looking for CAD, CAM or CNC?
- wodji
02 May 2018 01:06 #109985
by wodji
Replied by wodji on topic Hi
I looking for something what would do calculation of start positions of each cuttings and sent them to cnc software.
- wodji
02 May 2018 01:08 #109987
by wodji
It must be very easy for operator. He just will enter length of rail press calculate and start.
02 May 2018 10:25 #110010
What is the input data that the calculations are based on? (Solid model? Cutting list? Paper drawing?)
This might be possible to do in a custom GUI entirely inside LinuxCNC. See a similar example (part finished) here:
forum.linuxcnc.org/38-general-linuxcnc-q...ideas?start=10#82686
- wodji
02 May 2018 10:42 #110012
by wodji
Input is shape of cutting which could be gcode, length of hand rail, pitch and min distance from ends of hand rail to edges of cutting.
03 May 2018 00:01 #110076
Does a table-entry in the GUI like my example get close?
Time to create page: 3.234 seconds
