Vismach Simple Example
- jean-claude
26 Jun 2018 11:07 #112875
by jean-claude
Replied by jean-claude on topic Vismach Simple Example
Hello, I managed to simulate my machine in Vismach. Is it possible to reset the 'position.txt' and '* .var' files to zero when starting linuxcnc.
@++ Jean Claude
@++ Jean Claude
- Thank you received: 4647
26 Jun 2018 11:38 #112877
Replied by andypugh on topic Vismach Simple Example
You can simply choose not to use the position.txt file by removing it from the INI file.
Which .var file entries are causing trouble? You can edit the file to remove any parameters that you do not wish to be persistent.
- jean-claude
26 Jun 2018 11:48 #112878
by jean-claude
Ok, I just removed the position.txt file in the INI file. It seems to work.
Thank you
@++ Jean Claude
Thank you
@++ Jean Claude
Time to create page: 0.075 seconds
