Help with Emco Concept Mill 55
05 Oct 2018 01:55 #118452 by Harleyvet02
Replied by Harleyvet02 on topic Help with Emco Concept Mill 55
So I have LinuxCNC running on an older desktop machine. I have never used Linux so please bear with me. I installed the 5i25 card and ran PNCCONF. When I get to the screen for select 5i25 from the Mesa0 PCI/Parport card there is nothing behind the colon.
I have run "lspci" from root terminal and do not see anything with "Mesa" or "5i25" listed. I have tried moving PCI slots but no difference. I know there is power because the 2 LEDs flash on the board at power up and the 7i76 board's LED is lit.
Any help would be appreciated. I have spent hours looking for an answer and I'm stumped.
05 Oct 2018 03:47 #118453 by PCW
Replied by PCW on topic Help with Emco Concept Mill 55
I think that's normal ( I dont think pncconf accesses any hardware unless you use the "test/tune axis"' pane )
I would just page forward to the Mesa Card 0 page, select "5i25 internal data" and "7i76x2 With One 7i76"
select "Accept components Changes" and continue.
If the 5I25 is found by the system,
"lspc -nn" should show a pci device with 2718:5125 vendor:device ID
06 Oct 2018 03:46 #118487 by cmorley
Replied by cmorley on topic Help with Emco Concept Mill 55
What version of linuxcnc are you using?
As Peter said: select '5i25 internal data' on the mesa0 page.
If that isn't an option then it sounds like you are using an old version of linuxcnc
Chris M
08 Oct 2018 16:40 #118545 by Harleyvet02
The card is recognized via "lspci -n" as 2718:5i25.
I am trying to use a TB6600 driver off of ebay and a stepper motor I had laying around. I am not having any luck so far. I previously used this driver and motor with a Raspberry Pi Protoneir hat and it was working. Has anyone used this driver? I would like to bench test this setup since the Mill is in the garage and testing will be a little challenging. I would also be willing to pick up another stepper driver for testing if someone can give a suggestion. Thanks for all of your help and patience.
08 Oct 2018 19:35 #118554 by andypugh
Replied by andypugh on topic Help with Emco Concept Mill 55
The driver you have ought to work, but you might need a different firmware on the 5i25.
Do you know what firmware is currently on the 5i25?
10 Oct 2018 19:51 #118653 by Harleyvet02
I believe the firmware is up to date. I performed apt -get update and flashed with mesaflash. I may have a chance to work with it tonight as well. Any other diagnostics I can do to check the 5i25 and 7i76 are working?
10 Oct 2018 20:01 #118654 by PCW
What do you believe is not working?
Most common start up issues with step drives are wrong wiring (step/dir swapped for example) or too narrow step pulses
( Start with 10 usec (10000 ns) if you don't have drive specs)
11 Oct 2018 01:11 #118661 by Harleyvet02
Success! At least a little. I have movement while testing the X axis in pncconf. Stepper seems to be moving appropriately. Pulse (+), Dir (+), and EN(+) all need to be jumpered together. I had forgotten that when I last used this driver. Thanks for all the help. I’m moving on to using the Axis GUI.
12 Oct 2018 12:09 #118699 by andypugh
They quite often need to be jumpered together _and_ connected to +5V
Do you have any docs for the driver?
Time to create page: 0.757 seconds
