Intel DG41MJ Not finding Parallel Port
- brosskgm
28 Sep 2018 23:44 #118161
by brosskgm
Replied by brosskgm on topic Intel DG41MJ Not finding Parallel Port
Well, I did get a clean install. Now I'm getting an error I've never seen before.
I get the debug screen when I tru to run LinuxCNC
DEBUG FILE INFORMATION
insmod: error inserting '/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hal_parport.ko': -1 Resource temporarily unavailable
./3020T_CNC.hal:6: exit value: 1
./3020T_CNC.hal:6: insmod for hal_parport failed, returned -1
I'm looking through the forum to see if this is covered.
- brosskgm
28 Sep 2018 23:58 #118162
by brosskgm
Clean install. Had a few startup errors running LinuxCNC.
Getting closer. LinuxCNC now runs, but still does not give the power clicker or able to run tests in stepconf.
- Thank you received: 7490
29 Sep 2018 05:29 #118167
Replied by tommylight on topic Intel DG41MJ Not finding Parallel Port
As far as i remember, that happens when setting the wrong address and it will not work without rebooting the PC and fixing the address.Well, I did get a clean install. Now I'm getting an error I've never seen before.
- brosskgm
29 Sep 2018 11:10 - 29 Sep 2018 11:12 #118173
by brosskgm
I did get past that. Getting closer.
I blacklisted lp
dmesg | grep par
[ 0.004048] AppArmor: AppArmor disabled by boot time parameter
[ 0.142956] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 10.231352] parport0: PC-style at 0x378, irq 0 [PCSPP,TRISTATE]
[ 10.231360] parport0: irq 0 in use, resorting to polled operation
[ 10.792084] ppdev: user-space parallel port driver
lpinfo -v
network http
network https
network ipp
network ipps
network socket
network lpd
network beh
network ipp14
network smb
direct hp
direct hpfax
cat /proc/ioports
0378-037a : parport0
CNC.hal
loadrt hal_parport cfg="0x0378 out"
setp parport.0.reset-time 3000
I tried both ways
loadrt hal_parport cfg="0x378 out"
I'm at a loss.
I blacklisted lp
dmesg | grep par
lpinfo -v
network http
network https
network ipp
network ipps
network socket
network lpd
network beh
network ipp14
network smb
direct hp
direct hpfax
cat /proc/ioports
CNC.hal
I tried both ways
I'm at a loss.
Last edit: 29 Sep 2018 11:12 by brosskgm.
29 Sep 2018 13:46 #118176
Does that mainboard have a BIOS at all ?
There must be settings for parallel port, you need to set it to EPP or ECP mode in bios, set it to use DMA and IRQ, otherwise it will not work.
You have it set as Tristate and not using IRQ ( IRQ 0 is reserved, can not be used by parallel port).
- brosskgm
29 Sep 2018 13:56 #118177
by brosskgm
I did mention I had it set for bi-directional. I reset it for EPP, It doesn't give the option for Tristate. Just asks enable or disable and mode EPP, ECP, or bi-directional is all it gives.
It doesn't give a choice for DMA or IRQ.
- brosskgm
29 Sep 2018 14:27 #118178
by brosskgm
I'm re-installing. I've made so many changes I now have two parports and even deleting all conf & modules entries they don't go away on reboot.
- brosskgm
29 Sep 2018 17:39 #118182
by brosskgm
After a full clean install before installing the RTAI kernel
cat /proc/ioports now shows two parports. Is the EPP setting causing this?
037b-037f : parport0
dmesg now shows the Tristate & EPP & IRQ 5 you talked about.
I'll now install the kernel and see if it keeps this all.
dmesg | grep par
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.081455] regulator-dummy: no parameters
[ 0.130617] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 2.132676] Asymmetric key parser 'x509' registered
[ 11.683793] parport_pc 00:03: reported by Plug and Play ACPI
[ 11.683819] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE,EPP]
[ 11.780152] lp0: using parport0 (interrupt-driven).
[ 11.835940] ppdev: user-space parallel port driver
lpinfo -v
network http
network https
network ipp
network ipps
network beh
network ipp14
network socket
network lpd
direct parallel:/dev/lp0
direct hp
network smb
direct hpfax
dmesg | grep par
lpinfo -v
network http
network https
network ipp
network ipps
network beh
network ipp14
network socket
network lpd
direct hp
network smb
direct hpfax
- brosskgm
29 Sep 2018 17:59 #118184
by brosskgm
So far might be doing good. The only thing different from this install and the previous one is I didn't remove a lot of bloatware.
Now to install LinuxCNC and see what happens.
dmesg | grep par
[ 0.004049] AppArmor: AppArmor disabled by boot time parameter
[ 0.143128] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 9.220048] parport_pc 00:04: reported by Plug and Play ACPI
[ 9.220073] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE,EPP]
[ 9.236261] ppdev: user-space parallel port driver
[ 9.316458] lp0: using parport0 (interrupt-driven).
dmesg | grep par
- brosskgm
29 Sep 2018 18:36 #118185
by brosskgm
Still not getting the power clicker when I run the program, and did not work when trying to test during stepconf.
I think I need to give up on this. Nothing seems to be working at all.
The only other thing different is the Hard drive is a 1T. The old IDE drive in the older board is 80-gig.
I guess I could try a 160-gig drive. But don't really think that would be a problem.
Time to create page: 0.346 seconds
