New to Linux-LinuxCNC.... have questions
- w4swasey
19 Oct 2018 15:24 #119077
by w4swasey
New to Linux-LinuxCNC.... have questions was created by w4swasey
I currently own a CNC burning table (Ox/Fuel) operating on WinXP & Mach3. so Building a CNC machine isn't all new to me.
Wanting to build a 2nd. table using plasma Want to get away from Windows & their constant built in obsolescence....
It has been 11+ years since I built 1st. table. so I'm quite out of touch with what is out there.
Would like to use Ethernet to breakout board as opposed to Parallel port or USB of course need Home switches & a good THC Will be using a Hypertherm 1250 plasma
Would like recommendations on where to source the electronic parts I need
Already have a good power supply, Gecko 203V drives & robust NEMA-34 steppers.
- Thank you received: 4652
19 Oct 2018 16:07 - 19 Oct 2018 16:08 #119079
Replied by andypugh on topic New to Linux-LinuxCNC.... have questions
Ethernet is a good choice for a plasma build as it has good noise tolerance.
There is a thread here discussing plasma:
forum.linuxcnc.org/plasma-laser/35349-op...ea-and-a-lot-of-info
The most popular ethernet control card with LinuxCNC is probably the 7i76E but that is a bit excessive (and expensive) for a plasma table.
The 7i96 is probably more appropriate and still has screw-terminals for convenient wiring. There are cheaper options still, such as the 7i92 and 7i93 but those do not have screw terminals so you would need to source and wire connectors. (of course, that can also be an advantage)
Last edit: 19 Oct 2018 16:08 by andypugh.
The following user(s) said Thank You: tommylight, w4swasey
- Thank you received: 4144
20 Oct 2018 01:20 #119099
Personally, I disagree with Andy here. Plasma needs a lot more Inputs than most other machines so the 7i76e is a very good choice. I found it was possible to use all of the inputs.
Replied by rodw on topic New to Linux-LinuxCNC.... have questions
The following user(s) said Thank You: w4swasey
- Thank you received: 7470
20 Oct 2018 09:12 #119110
Plasma needs as a minimum 4 inputs to work properly WITH THC,
- Probe or floating switch
- ARCOK signal from plasma or THC ( Proma THC 150 provides that from analysing the voltage )
- UP from THC
- DOWN from THC
That is with no limit switches or home switches. For that even the parallel port has enough inputs.
Some parallel ports can be configured for IN or OUT or X mode so the number of inputs and outputs can be changed as needed. Adding another parallel port PCI or PCI-express card is always a cheap option for more I/O.
7i96 from Mesa has 11 inputs so that will provide for the above and as below
- E-STOP
- 3x Home switches for all three axis that should also be used as limits for their respective axis
- 3x Limit switches for the negative side of their respective axis.
That should complete a normal machine.
On machines that use DC servo motors i use always another set of limit switches ( 2 for each axis ) as extreme limit switches that are wired to a relay that will cut the power to the machine in case one of them is triggered. This is in case the drives fail, usually they will short one of the outputs and send all the power to the motor so even stopping the enable signal will not work in some cases.
Adding some physical switches to the control panel is also very useful so that would require more inputs or a Mesa 7i73 that has also encoder inputs for MPG and can control a small display and some keyboards. All this is still cheaper than a touch screen monitor.
Replied by tommylight on topic New to Linux-LinuxCNC.... have questions
- UP from THC
- DOWN from THC
- E-STOP
20 Oct 2018 10:02 #119114
Plus:
extra home switch to use Master Joint Axis to square entry
I prefer seperate home and limit switches as you can get larger usable area
torch breakaway switch
Scale select for 7i76e MPG (2 min)
Axis select for 7i76e MPG (2 min)
Warning lights (I have 3)
Run/Step button
Pause/Resume button
Drive disable output
motion.digital-in.00 for M66
Pendant e-stop
Pendant features (4)
I've not listed all I've used. What about downdraft zoning?
We are talking a large machine so a few extra inputs and outputs gives a much better user experience.
Run/Step button
Pause/Resume button
Pendant e-stop
20 Oct 2018 10:08 #119116
Thank you, Rod.
Will add that info to the plasma thread so we can have all the information gathered in one place.
The following user(s) said Thank You: rodw, w4swasey
- w4swasey
20 Oct 2018 18:31 #119127
by w4swasey
Replied by w4swasey on topic New to Linux-LinuxCNC.... have questions
Thanks to everyone for the input !
When looking at the THCAD-10 & the THCAD-300
Can someone thee me which is the better choice for a Hypertherm 1250?
The HT 1250 I have was purchased as a hand held torch. I did purchase a machine torch to fit the machine.
- billykid
- Thank you received: 83
20 Oct 2018 19:05 #119128
by billykid
Replied by billykid on topic New to Linux-LinuxCNC.... have questions
hyperterm 1250 is a great machine .. I would take thcad10 without a doubt, since your plasma has a 50: 1 internal divider available on the 14-pin socket on the back.
- w4swasey
20 Oct 2018 19:23 #119131
by w4swasey
I purchased the HT1250 planning to add it to an existing Ox/Fuel table I built a few year before. Then didn't add it because of no water table or good way to remove most of the airborne dust & smoke from the shop environment. It's still in the box!! Wad purchased shortly before thr Powermax 30,40 etc. series hit the market
20 Oct 2018 20:45 #119141
In your case that is the choice .hyperterm 1250 is a great machine .. I would take thcad10 without a doubt, since your plasma has a 50: 1 internal divider available on the 14-pin socket on the back.
Time to create page: 0.209 seconds
