- Thank you received: 2349
Plasma Cutter causes communications lost with 7176.
8 years 1 week ago #119369
by Grotius
Replied by Grotius on topic Plasma Cutter causes communications lost with 7176.
Okey.
Move your pc and Control box and usb cables from the iron machine. Dont let one wire touch the machine.
If the machine is working good without
Plasma arc?
So yes.
Do a program and do the plasma torch contact extern. Torch normally open contact by hand.
If this is good.
You are almost where you want to be.
Try to find your disturbing source step
By step.
Good luck. Mesa can not do anything
About your problem.
Okey.
Plasma arc?
So yes.
If this is good.
By step.
About your problem.
- skitter_ranch
- Topic Author
8 years 1 week ago #119372
by skitter_ranch
Replied by skitter_ranch on topic Plasma Cutter causes communications lost with 7176.
The machine works just fine UNTIL the trigger of the Cutter is set. I/O is no problem. Estop works, relay works.
As stated earlier, the Cutter was completely separated (the other side of the garage). NO physical connection. Only the same power line.
- skitter_ranch
- Topic Author
8 years 1 week ago #119373
by skitter_ranch
Oh, and I forgot, I have scanned through the Plasma files, but don't see anything relating to what I am experiencing. I will keep reading.
Thanks for your input.
8 years 1 week ago - 8 years 1 week ago #119374
by Grotius
Disconnect plasma start. Do this by hand in running program. Is machine cutting without problems?
It can a problem in the inverter plasma start wiring
Last edit: 8 years 1 week ago by Grotius.
8 years 1 week ago #119379
Replied by tommylight on topic Plasma Cutter causes communications lost with 7176.
8 years 1 week ago #119387
Replied by rodw on topic Plasma Cutter causes communications lost with 7176.
Noise like this is certainly frustrating. I had similar issues with my 7i76e. Good grounding according to a Hypertherm document about a star ground was helpful and involved running a wire back to the star point from every stepper/servo motor.
I even purchased a USB oscilloscope to get a better handle on it all. One of the most effective things I did was replace the IEC power connector with an EMI filter like this. www.jaycar.com.au/iec-emi-power-line-filter-6-amp/p/MS4003
At one stage, I added a similar filter to the raw arc voltage in the plasma cutter itself. However, eventually I removed it and found it was not needed. In my case the noise was interfering with the arc voltage from the THCAD so it was impossible to do any THC adjustment.
The oscilloscope was useful as it helped me isolate the noise was coming from the control box, not the plasma cutter.
So welcome to the noobie plasma dance! I found there were so many things I had absolutely no clue about with electronics that is second nature to guys like PCW who are immersed in this stuff every day.
