A couple genral questions
- allenwg2005
- Thank you received: 4
08 Nov 2018 17:37 #120280
by allenwg2005
Replied by allenwg2005 on topic A couple genral questions
I have a block I use the same position on each time.
I'm think I recall years ago this system worked, I can't say which change buggered it up but it would be nice to have it working again.
I used a measuring station on my Walter Large Power years ago, it sure made thing much easier and way more accurate. (Sold the company so those toys are gone).
- Thank you received: 4652
08 Nov 2018 18:13 #120281
Replied by andypugh on topic A couple genral questions
When you touch the block, what number do you put in the touch-off dialog?
- allenwg2005
08 Nov 2018 20:35 #120289
by allenwg2005
I put in 0.00 for all of them.
I thought they just needed to be relative to each other, the program reads the table and applied the "H" value when G43 was called.
Am I wrong?
Am I wrong?
08 Nov 2018 23:35 #120298
No, zero is probably right.
What does the DRO show the Z coordinate as, after touch-off?
