Help loading programs in Gmoccapy
13 Nov 2018 17:25 #120581 by sean87wk
Help loading programs in Gmoccapy was created by sean87wk
Hi, I'm testing out Gmoccapy after using Axis display for a few years and I'm having issues loading a program. When I try to load a program it doesn't display any files in the folders I am navigating through. My g-code files are all .nc files. Do my g-code files need a certain extension to be selected in Gmoccapy? Is there something I need to edit in the settings or .ini? Thank you!
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
13 Nov 2018 19:19 #120598 by rodw
Replied by rodw on topic Help loading programs in Gmoccapy
Try
mv *.nc *.ngc
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
13 Nov 2018 19:24 #120599 by rodw
13 Nov 2018 20:37 #120608 by sean87wk
Replied by sean87wk on topic Help loading programs in Gmoccapy
Ok, I'll give those a try tonight. Thank you.
14 Nov 2018 02:54 #120651 by sean87wk
That did it! Thank you!
Time to create page: 0.274 seconds
