Manjaro + LinuxCNC?
7 years 11 months ago #120755 by eFalegname
I've got to say that I'm very impressed of the work with Manjaro, at this moment Manjaro is in the first place in the ranking of Distrowatch , personally I'm trying it now, it is faster and more productive than Linuxmint, also more user-friendly. Definitively this is the way to go with Linuxcnc ;) . In arch repositories you can find Linuxcnc simulation module, but Manjaro has a graphical interface so is possible to switch among several kernels including Real Time ones.
Is there anyone who has succeeded in installing and running LinuxCNC RTAI on Manjaro x 86?
7 years 11 months ago - 7 years 11 months ago #120802 by eFalegname
Replied by eFalegname on topic Manjaro + LinuxCNC?
Easy install...
Last edit: 7 years 11 months ago by eFalegname.
The following user(s) said Thank You: tommylight, pommen
7 years 2 months ago #142741 by sage
Replied by sage on topic Manjaro + LinuxCNC?
First of all, thanks for the nice video.
I tried it with the command: pamac build linuxcnc to get it installed, which is pretty much the same. However, after lots of compilation, it ends up with the error message:
Building linuxcnc...
==> Making package: linuxcnc 2.7.14-2 (Do 22 Aug 2019 00:42:29 CEST)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
==> Retrieving sources...
==> ERROR: /var/tmp/pamac-build-sage/linuxcnc/ is not a clone of git://github.com/LinuxCNC/linuxcnc.git
Aborting...
Anybody any idea what went wrong?
Thanks a lot.
7 years 2 months ago #142790 by pl7i92
Replied by pl7i92 on topic Manjaro + LinuxCNC?
yiu cand clone it to a temporay folder
you need a real one preferd in the main structure of the user directory HOME/user/linuxcncclone
7 years 2 months ago #142825 by sage
OK, I changed the build directory in the pamac-manager AUR Settings to "/home/myUserName" (which is sage)
Same effect:
Preparing...
Cloning linuxcnc build files...
Checking linuxcnc dependencies...
==> Making package: linuxcnc 2.7.14-2 (Do 22 Aug 2019 13:32:54 CEST)
==> ERROR: /home/sage/pamac-build/linuxcnc/ is not a clone of git://github.com/LinuxCNC/linuxcnc.git
Aborting...
The source URL in the PKGBUILD file seems to point to the right place. Or not?
source=($_gitname::"git://github.com/LinuxCNC/linuxcnc.git#tag=v$pkgver" 'linuxcnc.sh' 'libtirpc.patch')
7 years 2 months ago #142826 by rodw
Replied by rodw on topic Manjaro + LinuxCNC?
I recommend you stick to the default directory ~/linuxcnc-dev
Follow the docs (this link is assuming you are compiling master branch)
linuxcnc.org/docs/devel/html/code/building-linuxcnc.html
Time to create page: 0.338 seconds
