Manjaro + LinuxCNC?
- eFalegname
- Thank you received: 30
15 Nov 2018 15:18 #120755
by eFalegname
Manjaro + LinuxCNC? was created by eFalegname
I've got to say that I'm very impressed of the work with Manjaro, at this moment Manjaro is in the first place in the ranking of
Distrowatch
, personally I'm trying it now, it is faster and more productive than Linuxmint, also more user-friendly. Definitively this is the way to go with Linuxcnc
. In arch repositories you can find Linuxcnc simulation module, but Manjaro has a graphical interface so is possible to switch among several kernels including Real Time ones.
Is there anyone who has succeeded in installing and running LinuxCNC RTAI on Manjaro x 86?
- eFalegname
16 Nov 2018 01:16 - 16 Nov 2018 02:22 #120802
by eFalegname
Replied by eFalegname on topic Manjaro + LinuxCNC?
Easy install...
Last edit: 16 Nov 2018 02:22 by eFalegname.
The following user(s) said Thank You: tommylight, pommen
- sage
21 Aug 2019 21:12 #142741
by sage
Replied by sage on topic Manjaro + LinuxCNC?
First of all, thanks for the nice video.
I tried it with the command: pamac build linuxcnc to get it installed, which is pretty much the same. However, after lots of compilation, it ends up with the error message:
Building linuxcnc...
==> Making package: linuxcnc 2.7.14-2 (Do 22 Aug 2019 00:42:29 CEST)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
==> Retrieving sources...
==> ERROR: /var/tmp/pamac-build-sage/linuxcnc/ is not a clone of git://github.com/LinuxCNC/linuxcnc.git
Aborting...
Anybody any idea what went wrong?
Thanks a lot.
Aborting...
Thanks a lot.
- pl7i92
- Thank you received: 358
22 Aug 2019 06:07 #142790
by pl7i92
Replied by pl7i92 on topic Manjaro + LinuxCNC?
yiu cand clone it to a temporay folder
you need a real one preferd in the main structure of the user directory HOME/user/linuxcncclone
- sage
22 Aug 2019 09:51 #142825
by sage
OK, I changed the build directory in the pamac-manager AUR Settings to "/home/myUserName" (which is sage)
Same effect:
Preparing...
Cloning linuxcnc build files...
Checking linuxcnc dependencies...
==> Making package: linuxcnc 2.7.14-2 (Do 22 Aug 2019 13:32:54 CEST)
==> ERROR: /home/sage/pamac-build/linuxcnc/ is not a clone of git://github.com/LinuxCNC/linuxcnc.git
Aborting...
The source URL in the PKGBUILD file seems to point to the right place. Or not?
source=($_gitname::"git://github.com/LinuxCNC/linuxcnc.git#tag=v$pkgver" 'linuxcnc.sh' 'libtirpc.patch')
Same effect:
Preparing...
Aborting...
- Thank you received: 4145
22 Aug 2019 11:11 #142826
Replied by rodw on topic Manjaro + LinuxCNC?
I recommend you stick to the default directory ~/linuxcnc-dev
Follow the docs (this link is assuming you are compiling master branch)
linuxcnc.org/docs/devel/html/code/building-linuxcnc.html
- sage
27 Aug 2019 14:24 #143325
by sage
I followed the docs in linuxcnc.org/docs/devel/html/code/building-linuxcnc.html
After successful cloning and ./autogen.sh, -/configure shows following error:
checking version of python libraries... python3.7m
checking match between tk and Tkinter versions... 8.6
checking location of Python header files... /usr/include/python3.7m
checking for Python headers... -I/usr/include/python3.7m
checking for Python libraries... -lcrypt -lpthread -ldl -lutil
checking whether the Boost::Python headers are available... yes
checking for boost::python shared library...
configure: error: boost::python is required to build LinuxCNC
However, boost is installed:
sudo pacman -S boost
warning: boost-1.69.0-2 is up to date -- reinstalling
Still the same error;
I can't find any package in any Arch Linux repository (core, extra community AUR...) named boost::python.
- Thank you received: 7468
27 Aug 2019 14:56 #143327
Replied by tommylight on topic Manjaro + LinuxCNC?
IRC it should be
Libboost-python
Libboost-python
- sage
27 Aug 2019 15:23 #143328
by sage
IRC it should be
Libboost-python
There is boost and boost-libs. Both are installed. There is no such package called "libboost-python" in Arch Linux / Manjaro standard repos nor in AUR
Libboost-python
- sage
27 Aug 2019 15:34 #143329
by sage
Linuxcnc-sim installs like charm with AUR just like in the above video.
Linuxcnc (without sim) does not. This is when the error accurs:
==> ERROR: /home/user/pamac-build/linuxcnc/ is not a clone of git://github.com/LinuxCNC/linuxcnc.git
Aborting...
Maybe there is some error somewhere in the AUR PKGBUILD or something just missing.
Aborting...
Time to create page: 0.133 seconds
