Lathe with Mesa 5i25 and G540
29 Nov 2018 03:34 #121575 by micahvestal
Lathe with Mesa 5i25 and G540 was created by micahvestal
I've done some searching and I'm still a little bit lost.
I am building a lathe with a Mesa 5i25 and a Gecko G540. I know that this particular configuration is not available in PnCCONF Wizard, but I'm curious if one of the available options is a good starting point? I don't mind doing the research and editing to add functionality. I am just hoping that doesn't mean that I have to write an INI and HAL file completely from scratch, because I think that would be a really steep learning curve.
I have already flashed firmware onto the 5i25 and I've looked at a some HAL and INI files that other members have posted here (unfortunately people usually only post their files when something is wrong with them). I appreciate any help I can get!
  • Moderator
  • Moderator
29 Nov 2018 09:54 #121585 by tommylight
Replied by tommylight on topic Lathe with Mesa 5i25 and G540
forum.linuxcnc.org/39-pncconf/32400-mesa-7i92m-support?start=60
That is for 7i92, but it is the same as 5i25 concerning the hal and ini files.
Here is a working config with charge pump, uses inches and you have to edit the scale and some other things to suit your machine.
The following user(s) said Thank You: micahvestal
01 Dec 2018 03:23 #121668 by robforbes
Replied by robforbes on topic Lathe with Mesa 5i25 and G540
I have a Mesa 5i25 and Gecko G540 controlling a lathe...let me know if you would like a copy of my config.
Rob
01 Dec 2018 18:42 #121682 by micahvestal
Replied by micahvestal on topic Lathe with Mesa 5i25 and G540
Thanks Rob, that would be great!
tommylight, I really appreciate the link! I will check that out as well.
Micah
01 Dec 2018 19:02 #121683 by micahvestal
I just updated LinuxCNC and the option for a 5i25 and G540 is now available in PcncConf. I am going to try to get a baseline configuration using PcncConf. I think that will help me wrap my mind around how the HAL and INI files actually work.
01 Dec 2018 20:04 #121687 by robforbes
My .hal file is attached. I was following a procedure with files that were posted online (maybe the same ones as the link above) and my notes say I ran into three small snags with that:
1) needed to delete "watchdog" lines from hal (else error occured)
2) corrected typo: change control_type to control-type
3) commented out "enable charge pump" line in hal as it was causing a "pin doesn't exist" error
Rob
10 Dec 2018 21:08 #122157 by micahvestal
I am poking around the attached HAL and INI files. The G540 generates holding power for both axes but the X axis does not move. Z axis moves as expected.
I tried moving the X axis stepper to the Y axis plug on the G540 and the Y axis worked just fine.
Am I missing something super obvious here? I'm a complete noob, so I won't be surprised if it's an easy fix.
10 Dec 2018 21:35 #122159 by PCW
Replied by PCW on topic Lathe with Mesa 5i25 and G540
I would first try setting the steplength on all channels to 2500 ns
10 Dec 2018 21:38 #122161 by PCW
Plus uncomment all the x axis connections they are all commented out in your hal file
10 Dec 2018 21:39 #122162 by micahvestal
Okay, cool. I have changed all axes to STEPLEN=2500. X Axis still doesn't move though.
Time to create page: 0.247 seconds
