andypugh wrote: I am talking about the LinuxCNC tool table.
(probably in your config folder, and called "tool.tbl")
Most LinuxCNC GUIs have a menu item "edit tool table". Open that and make sure that the X and Y offsets for every tool are zero. (It is very unlikely that any rotating-tool machine will need X or Y offsets, they exist for plasma, laser, lathe etc.
bevins wrote: For the tearout, try using a downspiral. looks like either the bit is not sharp or you need to use a down spiral bit.
Just my .02.
