toolchange protocol and manual toolchange touchoff
- frogandspanner
14 Dec 2018 16:45 #122430
by frogandspanner
toolchange protocol and manual toolchange touchoff was created by frogandspanner
I have been trying to use python code I found that provides for manual touchoff during toolchange, but it does not work reliably, so I tried to understand a rewrite the code.
I went back to the toolchange documentation: wiki.linuxcnc.org/cgi-bin/wiki.pl?ToolChange
mymill.hal includes a line net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
so the tool prepare cycle is self-satisfied.
My understanding of the tool-change/tool-changed stage of the process is that tool-change is set to demand a tool change, *and remains set until tool-changed is set*, but if I set a watch on the pin I see it flash on and off (if I see it at all), even though tool-changed is reset. Am I misunderstanding this part of the protocol?
- Thank you received: 4659
15 Dec 2018 06:19 #122440
No, you are right. But it looks like something is resetting tool-changed for you.
Possibly the Python code.
It sounds like you have a remap in effect for M6, if you are calling Python. Is there a REMAP statement in the [RS274NGC] section of the INI?
Replied by andypugh on topic toolchange protocol and manual toolchange touchoff
- pl7i92
- Thank you received: 359
15 Dec 2018 08:17 #122443
by pl7i92
Replied by pl7i92 on topic toolchange protocol and manual toolchange touchoff
Why Dont You use just a Mcode to do this
or even a Side Button to Set Your zero by NGC
You might set it by G10 L20 P1 Z0 Sets G54 ZZero
needs a reload CAN also be done by Mcode to set the Display
o<znullen> sub
G91 ( relative mode for probing)
G38.2 Z-25 F100 ( trip switch on the way down)
G90 ( absolute mode)
G92 Z0
G1 Z3.5 F150
o<znullen> endsub
M2You might set it by G10 L20 P1 Z0 Sets G54 ZZero
- frogandspanner
15 Dec 2018 18:00 #122462
by frogandspanner
Replied by frogandspanner on topic toolchange protocol and manual toolchange touchoff
Possibly the Python code."
I have been cutting down the Python code to the minimum, then back to failing, to see whether that is responsible, and have discovered that it's a linuxcnc.command.abort that clears the change bit.
linuxcnc.org/docs/2.6/html/code/Code_Notes.html#_abort
suggests that "The ABORT command simply stops all motion" and "It does not . . . change any state information"
so I am confused.
In what source file can I find linuxcnc.command.abort is implemented?
I am relatively new to linuxCNC, and am finding it extremely difficult to navigate the code.
so I am confused.
- frogandspanner
15 Dec 2018 18:05 #122463
by frogandspanner
"Why Dont You use just a Mcode to do this
or even a Side Button to Set Your zero by NGC"
I wish I understood what you suggested!
Thanks for the pointer - I'll look at your suggestion and see if I can work it out.
15 Dec 2018 18:18 #122464
I think being in the middle fo a tool change probably counts as a motion.
Where did you get the Python code from? Is it a remap? (and, also. why os it aborting?)
- pl7i92
16 Dec 2018 09:41 #122480
by pl7i92
on Manuel Tool Change it is Just Tx M6 to call the Tool from the Table
As Diameter only is needed
IF there is no Toolchanger
THEN Go to the Part if methal ad a Crocodile clamp to the tool
and MDI
G38.5 Z-5 F40 (5is the absaolute so look at the DRO First)
The Tool Will probe and stop
Set the New Zero and start over
You can Automate that with a button press
IF the Part is not Metall then use a Simple Copper plate PCB Pice to get the Thickness
WORKES FINE
and MDI
WORKES FINE
- frogandspanner
16 Dec 2018 11:56 #122486
by frogandspanner
16 Dec 2018 12:18 #122487
Ah, OK. Now it is a little more clear.
Would an automatic tool-length probe work better? It's rather easier to make work, I believe.
The other alternative, and one that actually works pretty well (and is rather more flexible) is to split the G-code up into one file for each tool.
This also gives you the option of using one tool on many parts, as sometimes it is quicker and easier to swap workpieces than tools.
- pl7i92
17 Dec 2018 03:29 #122510
by pl7i92
Not Clear is as He Has a Toolchanger Magazin or even Toolclamps for all the tools
Separate
Or Changes the Tool's into one Clamp
Separate
Time to create page: 0.237 seconds
