Relay to turn on spindle
29 Dec 2018 02:33 #123045 by Leon82
Relay to turn on spindle was created by Leon82
What type of relay would be used to turn on the spindle?
My grizzly g0463/siegx3 has a 110v dc motor(with brushes) it has forward and reverse drum switch and a potentiometer for speed.
I am finding topixs for the sx3 which uses a brushless motor.
The breakout board has a built in spindle relay but I'm not sure where to start with it.
29 Dec 2018 03:30 #123046 by JohnnyCNC
Replied by JohnnyCNC on topic Relay to turn on spindle
What are you using for a BOB? You need to know how much current and at what voltage the output can handle.
I have a Sieg X3 with a Mesa 7i76 and am using 24v for my field power so the relay I used may not work for you.
I used these Relays in my new cabinet and I really like them.
29 Dec 2018 03:42 #123048 by Leon82
Replied by Leon82 on topic Relay to turn on spindle
It's a $20 5 ax sainsmart. I'll have to look up the specs, but it's a cheap card.
29 Dec 2018 15:18 #123083 by pl7i92
Replied by pl7i92 on topic Relay to turn on spindle
you shoudt use a 2 relay setup
5V FTR relay that drives a 8A 12V or 24V relay block like Finder 40,52 or 61
you can use the Realys from the Arduino 5V
the BOB got a single relay on board if you havent used it then use it as the FTR to get the bigger relay to work
The following user(s) said Thank You: Leon82
29 Dec 2018 22:04 - 29 Dec 2018 22:14 #123116 by Leon82
Ok thanks.
The relay on the Bob I have(currently unused) closes when the spindle button is pressed. I'm having trouble finding a relay that can switch 110volt DC at 8amps. Most seem to be an 120/dc35 volts.
ETA spoke too soon
The reviews are iffy but maybe I can try it
www.amazon.com/gp/product/B075L5X5CT/ref...o00_s00?ie=UTF8&th=1
Last edit: 29 Dec 2018 22:14 by Leon82.
30 Dec 2018 06:24 #123134 by Leon82
I checked the voltage at the switch. It's actually ac 120volts because it's before it reaches the speed control. So I can use an ac relay.
04 Jan 2019 22:41 #123515 by Leon82
I was wrong
The forward reverse switch sees varying DC voltage up to 100volt. That's too much DC current for the relay in my board so it won't work. Switching just on the power cord wont work either because there is a safety fault switch
04 Jan 2019 23:03 - 05 Jan 2019 00:22 #123516 by Leon82
I could still be wrong.
The voltage varies at the switch but on DC I'm getting negative volts while the motor is running.
I think I'm over thinking this.if I put the relay on the black wire going to the motor it will work. I would just have to make sure the relay could handle the load. Which I think it will be too much.
Or I have to bypass the safety some how and switch the AC side
Last edit: 05 Jan 2019 00:22 by Leon82.
06 Jan 2019 13:40 #123603 by pl7i92
best to go to your local E-part dealer or simply to a TV-repair shop or a Electronic man that makes house installations they got relays in spare for Free
06 Jan 2019 15:58 #123609 by OT-CNC
Replied by OT-CNC on topic Relay to turn on spindle
I'm not familiar with your motor drive but in general you don't ever want to put a switch between the drive and the motor. You can blow the drive. Let the drive do the switching and speed control etc. If your drive doesn't have external inputs you would have to hack it or simply switch the ac supply assuming this is a small motor variable speed unit non VFD.
I would simply make a small relay box that has 2 outlets. Use 2 relays. Plug in the drive in one and have the other outlet control something like a small coolant pump etc.
I probably would not bypass the safety and just switch it on manually after issuing a M3. I think its more beneficial if the spindle stops automatically.
Just get a couple of solid state relays or mechanical ice cube/din rail ones rated above the inrush current of the drive.
Time to create page: 0.135 seconds
