Step through program with MPG
30 Dec 2018 23:14 #123174 by babinda01
Step through program with MPG was created by babinda01
Hi
I am currently building a plasma cutter, and would love to be able to use a mpg to step forward and backward through a gcode file, using the increments set for the mpg.
My thinking is that if I have a mishap, and need to go back to a point in the program where it stopped cutting, I could simply step throught the program with the mpg to find the exact point I want. Being able to step forwards and backwards would be fantastic.
So my first question is... Is this remotly possible with LinuxCNC? If so, where should I start my search for info.
Regards
Andrew
31 Dec 2018 01:06 #123180 by cmorley
Replied by cmorley on topic Step through program with MPG
There is a branch that allows forward and backward gcode movement.
There is no way to directly use an MPG to step through line-per-click.
You could probably rig something up to get close to that though.
I think the branch is reverse run _ I'm sure Rod will chime in soon - he is up on plasma code.
Chris M
01 Jan 2019 02:29 #123247 by rodw
Replied by rodw on topic Step through program with MPG
Chris M
If you insist. There is a branch called reverse run that is pretty old and has fallen behind. But PhilC has his own branch that includes the reverse run branch with a current master branch build and a working plasma config on this thread.
forum.linuxcnc.org/plasma-laser/35449-another-plasma-component
I'm not sure how Phill has configured the reverse run to step backwards in the file but Skunkworks (I think) has an example of using the Reverse run branch with a MPG in this video that is doing exactly what you want.
I think you just need to map the MPG count to the reverse run count in Hal somehow.
01 Jan 2019 07:46 #123253 by babinda01
Replied by babinda01 on topic Step through program with MPG
Thanks Chris & Rod. Exactly what I was looking for.
Time to create page: 0.310 seconds
