choosing a compatible tablet for a commercial cnc
- ihavenofish
- Thank you received: 286
07 Jan 2019 15:52 #123708
by ihavenofish
Replied by ihavenofish on topic choosing a compatible tablet for a commercial cnc
a little digging and it seems it DOES use a usb ethernet chip. sigh. oh well. also seems the bios isn't Linux very friendly. so not worth the effort.
- Thank you received: 4652
07 Jan 2019 15:58 #123709
Replied by andypugh on topic choosing a compatible tablet for a commercial cnc
What is inside the PocketNC? (I suspect it's a Beaglebone)
- ihavenofish
07 Jan 2019 16:07 #123710
by ihavenofish
seems to be yes.
- ihavenofish
07 Jan 2019 21:11 #123722
by ihavenofish
what about the UP board? pi footprint atom. realtek pcie lan.
www.mouser.ca/datasheet/2/826/UP-CHT01%2...2nd%20Ed-1100434.pdf
price isnt too horrible at 235cdn. still need the screen/panel but, the board can be stuffed right next to the mesa card.
- ihavenofish
07 Jan 2019 21:26 #123724
by ihavenofish
sounds like its a little tricky but can be made to work reading a few posts on the UP forums. ill dig some more but if anyone's tried it, let me know!
- ihavenofish
08 Jan 2019 03:16 #123745
by ihavenofish
so the Up is aaeon which is asus… which led me to all their actual industrial hmi's… which are kinda expensive, but not horrible since you don't need to add much in terms of mounting and they run of the main 24v psu and are temperature and shock rated.
10" with Celeron® N2807 Processor
eshop.aaeon.com/infotainment-multi-touch...utions-acp-1104.html
7" with Celeron® N3350 processor:
eshop.aaeon.com/multi-touch-panel-pc-for...inment-acp-1076.html
- ihavenofish
08 Jan 2019 05:48 #123749
by ihavenofish
this ones not in their retail store, but it looks like the ideal one. should come in under $600 + $40 for an msata drive in the volume I want. dual LAN, dual rs485, usb etc. comes in j1900. wifi is an option (just a card with antenna you can just buy yourself)
data-us.aaeon.com/DOWNLOAD/MANUAL/ACP-10...anual%202nd%20Ed.pdf
so... what would make this fail to work?
08 Jan 2019 13:40 #123775
PCI networking and built-in RS485 ports looks very promising.
It is specifically claimed to support Linux.
- Thank you received: 4144
08 Jan 2019 20:06 #123790
Replied by rodw on topic choosing a compatible tablet for a commercial cnc
I'd go with the N3350 version as I think its an upgrade to the J1900 which generally works. One of my Brix is a N3360 and it works
Latency might be high but quite OK for a Mesa ethernet card...
- ihavenofish
08 Jan 2019 20:14 #123792
by ihavenofish
might be required to g with the n3350 as the j1900 seems to be EOL end of the year. shame because it was slimmer.
you can also buy the pc separate for $310/single sample. wont strictly end up less money here than the all in one, but it give me some options to machine a front bezel with holes for e stop and on/off and some leds and an maybe an IPS screen with higher quality.
that box also has all the rs485's but as 9 pins instead of rj45.
Time to create page: 0.355 seconds
