Tool length sensor and touch probe with Mesa7i76e
- Muscats
17 Apr 2020 23:37 #164356
by Muscats
Replied by Muscats on topic Tool length sensor and touch probe with Mesa7i76e
Looks like a few issues there, thanks for that tip. This "toolnumber = 0 False" might be the issue?
Starting LinuxCNC...
Found file(REL): ./Pauls_LowRider2_new.hal
Found file(REL): ./custom.hal
note: MAXV max: 35.000 units/sec 2100.000 units/min
note: LJOG max: 35.000 units/sec 2100.000 units/min
note: LJOG default: 25.000 units/sec 1500.000 units/min
Warning: Forward kinematics must handle duplicate coordinate letters:yyzz
Note:
Individual axis homing is not currently supported for
KINEMATICS_IDENTITY with duplicate axis letter <Y>
Note:
KINEMATICS_IDENTITY with duplicate axis letter <Z>
note: jog_order='XYZ'
note: jog_invert=set([])
**** probe_screen GETINIINFO ****
Preference file path: /home/muscats/linuxcnc/configs/Pauls_LowRider2_new/Pauls_LowRider2_new.pref
**** PROBE SCREEN INFO ****
**** To many increments given in INI File for this screen ****
**** Only the first 5 will be reachable through this screen ****
Xlib.protocol.request.QueryExtension
73400323
task: 1327 cycles, min=0.000013, max=0.050719, avg=0.010162, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Note:
Note:
73400323
18 Apr 2020 00:27 #164363
Replied by andypugh on topic Tool length sensor and touch probe with Mesa7i76e
Can you zip up the config folder and attach it?
- Muscats
18 Apr 2020 01:41 - 18 Apr 2020 01:43 #164381
by Muscats
I will do. Out of the house dropping off some joeys, for pre-release, at the moment.
Last edit: 18 Apr 2020 01:43 by Muscats.
- Muscats
18 Apr 2020 02:01 #164384
by Muscats
I think I managed it remotely through my phone remoting through 2 computers
- Muscats
18 Apr 2020 05:26 #164405
by Muscats
Not sure that worked, when I checked the file I could not open it. Here is another one I created on my windows computer
- Muscats
18 Apr 2020 07:22 - 18 Apr 2020 07:23 #164424
by Muscats
@andypugh ,
I found a GITHUB fork for the Probe Screen with post 2.8 amendments ( github.com/GuiHue/probe_screen_v2 ) and installed that onto an old backup (pre installing a Z touch off plate (which I think may have been causing some issues too)), I gave it a quick try out and it seems to be doing the tool change correctly, though it did throw some "Exceed Z Max errors), which i think I had to correct previously due to my Z axis home at the top and all absolute moves being negative.
Last edit: 18 Apr 2020 07:23 by Muscats.
- ikkuh
- Thank you received: 48
22 May 2021 13:26 - 22 May 2021 13:27 #209837
by ikkuh
For everybody else who can not make this example work, there is a typo in the add command.
Replied by ikkuh on topic Tool length sensor and touch probe with Mesa7i76e
addf o2.0 servo-thread
addf or2.0 servo-thread
Last edit: 22 May 2021 13:27 by ikkuh.
24 May 2021 21:33 #210111
Thanks, fixed.
I will beat myself later.
- Thank you received: 7488
24 May 2021 23:11 #210133
Replied by tommylight on topic Tool length sensor and touch probe with Mesa7i76e
Need help ?
- jtrantow
- Thank you received: 26
13 Feb 2022 20:37 #234744
by jtrantow
Replied by jtrantow on topic Tool length sensor and touch probe with Mesa7i76e
Copy/paste error???
Original post has probe-in connected to both .in0 and .in1. I think you want tool-length connected to .in1.
Time to create page: 0.151 seconds
