Home switch clarification
- Leon82
- Thank you received: 79
31 Jan 2019 00:43 #125360
by Leon82
Replied by Leon82 on topic Home switch clarification
There was a field in there for home offset. I got it on the second try.
It's was a positive value even though it is minus from the switch. So after it homes it won't hit the switch unless it looses steps or the coupling slips
- Leon82
04 Feb 2019 17:19 #125671
by Leon82
Ok here's another question.
My y axis I currently have y0 plus like in most 3 axis machines. But fabricating a bracket would be easier to do it in the minus direction.
I could reverse it and use it as home and limit +
This way the y work offset would be positive but I could live with that. I've worked on robodrills that had x axis like this.
I'm not sure if I'm describing this right.
Is it possible to home the axis in the minus direction? I know there are several pin options available
- Thank you received: 1472
04 Feb 2019 20:40 #125683
Replied by Todd Zuercher on topic Home switch clarification
Yes the machine can be configured to home in either direction (+ or -). The direction that the machine seeks the home switch in is determined by the sign of the home velocity.
The following user(s) said Thank You: Leon82
Time to create page: 0.064 seconds
