Paralell port mode: AT, PS2, EPP, ECP, DMA...?
  • FridgeFreezer
  • FridgeFreezer's Avatar Topic Author
  • New Member
  • New Member
06 Feb 2019 12:21 #125798 by FridgeFreezer
Paralell port mode: AT, PS2, EPP, ECP, DMA...? was created by FridgeFreezer
Morning all, can anyone here tell which is the "preferred" mode to set your parallel port for best results?
My BIOS (Dell Optiplex 760) offers the following:
AT, PS/2, EPP, ECP no DMA, ECP DMA1, ECP DMA2
Ordinarily I'd assume ECP+DMA would be "best" but that's for data transfer, not accurately timed pulses, so can anyone point me the right way?
06 Feb 2019 13:21 #125802 by tommylight
Replied by tommylight on topic Paralell port mode: AT, PS2, EPP, ECP, DMA...?
For normal use as a parallel port, that will do just fine. For some types of Mesa and Pico boards that use parallel port as a communication bus it has to be set as EPP.
I always set mine to ECP.
The following user(s) said Thank You: sk_linuxcnc
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
06 Feb 2019 14:09 #125811 by Todd Zuercher
Replied by Todd Zuercher on topic Paralell port mode: AT, PS2, EPP, ECP, DMA...?
I think the best choice depends on what you are connecting to it.
For normal breakout board connections, I thing the best choice is usually the PS/2 (or Bidrictional, or SPP they are all the same) setting.
If you are using a Mesa card or Pico, then you have to use EPP.
That said many parallel port hardware implementations are slightly messed up. Which setting is chosen can (sometimes) make a difference in things such as which pins can be used as inputs or outputs and whether certain pins are pulled high or low (for example X-mode usually only works with the PS/2 setting). So try all and which ever works best for your hardware is the one to use. Of course they could all work equally well, and then it doesn't matter.
30 Jan 2025 19:44 #320173 by sk_linuxcnc
Replied by sk_linuxcnc on topic Paralell port mode: AT, PS2, EPP, ECP, DMA...?
Hello Sir. Could you please provide some help on this post? I am kind of facing a similar issue but i dont know how to change the data transfer mode of my parallel port to support 9 input pins. forum.linuxcnc.org/38-general-linuxcnc-q...with-9-inputs#320147
  • Platinum Member
  • Platinum Member
30 Jan 2025 20:49 #320178 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Paralell port mode: AT, PS2, EPP, ECP, DMA...?
NOT ALL PARALLEL PORTS SUPPORT MODE X, YOU HAVE BEEN ADVISED TO READ THE DATA SHEET PERTAINING TO THE CHIP. THIS IS THE THIRD TIME I HAVE ADVISED YOU TO DO THIS. I think you will find that the pins concerned are not open collector pins.
Time to create page: 0.099 seconds
