n00b: I might be an idiot? Set up help.
  • MoreAaron
  • MoreAaron's Avatar Topic Author
  • New Member
  • New Member
14 Mar 2019 01:15 #128552 by MoreAaron
n00b: I might be an idiot? Set up help. was created by MoreAaron
I have been unable to get the most basic of anything working so far. I've tried most everything I can find here or online and I'm either screwing everything up worse or...still screwing everything up worse.
I merely just want this accursed thing to make motors wiggle, then I can work from there.
Lemme try to provide as much info as I can. I've been trying to do this for a week and so far... zip.
PC: Just semi rando parts. Some quad core semprom. 6600 I think. 4Gb DDR2. Nvidia chipset.
Pci Parallel Port card (MCS9865) on address 0x378
C11G rev 9 BoB directly from cnc4pc.com
DM542S stepper driver (I have confirmed these work by manually pulsing them)
Running parallel port monitor. Nothing.
I've attatched a lspci -v printout, the ini file, and the hal file.
Also a picture of who it is currently sitting wired. E stop shorted, limit connected NC (though disabled in hal), EN shorted to 5V, etc etc.
Thank you in advance for any guidance... or if any of you are in DFW area. Dear lord I will pay you in money or beer to come do this crap for me. lol Now I shall go get a beer and try not to hit this stuff with the large assortment of hammers within my reach.
14 Mar 2019 07:43 #128559 by pl7i92
Replied by pl7i92 on topic n00b: I might be an idiot? Set up help.
Hi
it is saf to here that you are failing
THERE is a LIVE Chat room for direct Help that gets you more comfort by live acting on IRC Frenode
there are also multiple Videos of your bob and Configuration
I assume you messed up with the Estop
and DONT connect the 542 ENA* or ena- at al to the first moves
so you eleminate most errors
sorry im German and my understanding is not that good to advice you
but i got a Video online
The following user(s) said Thank You: MoreAaron
14 Mar 2019 12:21 #128579 by IrishMoss
Replied by IrishMoss on topic n00b: I might be an idiot? Set up help.
I have the same controllers, but a slightly different breakout board.
On mine, the Pul+/Dir+ are wired to the same +5v pin on the breakout board (all 3 of my controllers are connected to this same pin through a terminal block), and the Pul-/Dir- are wired to the ground pin.
I can't see the details of the pins on that breakoutboard in the pic, but that might be your issue, as I can see them connected to several different pins. But again, I don't know the layout of that board.
14 Mar 2019 13:50 - 14 Mar 2019 13:50 #128581 by andypugh
Replied by andypugh on topic n00b: I might be an idiot? Set up help.
It isn't, you know.
It seems to be at 0xdc00
Can you try that instead?
01:07.0 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller (prog-if 03 [IEEE1284])
Subsystem: Device a000:2000
Flags: bus master, medium devsel, latency 64, IRQ 17
I/O ports at dc00
I/O ports at d880
Memory at fcfdf000 (32-bit, non-prefetchable) [size=4K]
Memory at fcfde000 (32-bit, non-prefetchable) [size=4K]
Capabilities: <access denied>
Last edit: 14 Mar 2019 13:50 by andypugh.
  • MoreAaron
  • New Member
  • New Member
14 Mar 2019 15:34 #128589 by MoreAaron
Replied by MoreAaron on topic n00b: I might be an idiot? Set up help.
Hi
Your english is fine and better than my german which is remedial. :)
I shall search for this live chat and I will watch this video as soon as I get home.
Thank you for the tips.
Fair enough. I will try rewiring those once I get the parport to talk even a little bit.
It isn't, you know.
I/O ports at dc00
I/O ports at d880
I have tried that prior, but not since other misc. changes. I will attempt that tonight. "0xdc00 out" yes?
  • Moderator
  • Moderator
14 Mar 2019 16:07 #128590 by tommylight
Replied by tommylight on topic n00b: I might be an idiot? Set up help.
Or "0xd880 out".
Be sure to reboot the computer between address changes, as depending on what the address you tested does, it can hang initialising that address.
  • MoreAaron
  • New Member
  • New Member
14 Mar 2019 16:27 #128596 by MoreAaron
Thank you for that tip. That I did not know. Linux is a tricky devil.
  • Moderator
  • Moderator
14 Mar 2019 16:31 #128597 by tommylight
Naaah Linux is very user friendly, it is just picky who it's friends are ! :)
That issue with address changing i noticed twice and i have changed addresses more than i could count.
But it is an issue that could send you endlessly chasing gremlins, better to avoid that.
  • MoreAaron
  • New Member
  • New Member
15 Mar 2019 01:45 #128624 by MoreAaron
Well I have tried every single address I can find in lspci -v, proc ioports, etc.
lspci in op.
iports:
0378-037a : parport0
dc00-dc02 : parport1
dc03-dc07 : parport1
Nothing.
I've got a new IEEE1284parallel port cable otw which will arrive Saturday. Maybe my cable is shit. :dunno:
I'll probably check for one locally too cause waiting is for suckers. :)
Also... I've noticed now that the AD3 led is stuck on. Even when nothing is attached to any output pin. Could be nothing, but I guess I'll google around and see.
Thanks again for all the help so far and do keep any ideas, etc coming... before I get desperate and just order a centroid acorn. lol
15 Mar 2019 11:14 - 15 Mar 2019 11:16 #128649 by andypugh
You should be able to use
loadrt hal_parport cfg="0x378 out"
or
loadrt hal_parport cfg="0 out"
for the on-board parallel port (have you tried using that one?
And
loadrt hal_parport cfg="0xdc00 out"
or
loadrt hal_parport cfg="1 out"
for your PCI card.
dmesg might give you some more ideas what is going on.
I will assume that you are using the RTAI live CD
Open 2 terminal windows
In the first run these commands to clear and monitor the dmesg kernel log
tail -f /var/log/kern.log
This window will show kernel messages from the drivers as they are created (ignore any output in this window up to this point)
In the second window enter an interactive HAL session and try these commands.
halrun
Take a note (copy and paste) of any output in either window
you can then exit the HAL session
exit
and repeat the HAL commands in the same window with the other options and addresses.
Before you exit you can also read the parallel port pin states and set pin values, but to do that you need to load and start a realtime thread and add the parport functions to that
loadrt threads
addf parport.0.read thread1
addf parport.0.write thread1
start
show pin
and set the state of output pins
setp parport.0.pin-00-out 1
setp parport.0.pin-00-out 0
Last edit: 15 Mar 2019 11:16 by andypugh.
Time to create page: 0.291 seconds
