n00b: I might be an idiot? Set up help.
  • MoreAaron
  • MoreAaron's Avatar Topic Author
  • New Member
  • New Member
15 Mar 2019 14:52 #128661 by MoreAaron
Replied by MoreAaron on topic n00b: I might be an idiot? Set up help.
I will do all of that as soon as I get home. :)
The confusing thing is I am 99% sure the main board doesn't have a parallel port. I'll need to double check when I get home but I am pretty sure it is an Asus M3N78-VM
The back panel basically looks like this:
  • MoreAaron
  • New Member
  • New Member
15 Mar 2019 14:56 #128662 by MoreAaron
MF. Turns out there is one... it is internal. I never even thought to look for such a thing.
15 Mar 2019 15:11 #128664 by andypugh
Replied by andypugh on topic n00b: I might be an idiot? Set up help.
Add one of these and you have a standard COM port.
www.amazon.com/StarTech-com-Profile-Para...racket/dp/B009JXK5UE
LinuxCNC allows you to use both at the same time.
The following user(s) said Thank You: MoreAaron
  • MoreAaron
  • New Member
  • New Member
15 Mar 2019 15:49 #128665 by MoreAaron
Ordered. :)
15 Mar 2019 15:59 - 15 Mar 2019 16:00 #128666 by Leon82
Replied by Leon82 on topic n00b: I might be an idiot? Set up help.
My Asus board was the same way, and the bios had the address as 378
Last edit: 15 Mar 2019 16:00 by Leon82.
  • MoreAaron
  • New Member
  • New Member
15 Mar 2019 16:34 #128668 by MoreAaron
Yep. I thought I was setting the pci parallel port to 0x378 this entire time. :side:
  • MoreAaron
  • New Member
  • New Member
16 Mar 2019 02:19 - 16 Mar 2019 02:20 #128701 by MoreAaron
Gentlemen(and ladies), the port and C11G is working. Motors moving on bench. All things seem good.
I sourced a local DB25 to whatever ribbon cable and hooked it up to the randomly discovered internal LPT port of mystery and we have motion!
Thank you all for helping point me in the right direction. Now I can hopefully begin the next building phases.
Last edit: 16 Mar 2019 02:20 by MoreAaron.
