Solving some lingering F_error problems
- cogzoid
- Visitor
18 Mar 2019 23:45 #128950
by cogzoid
Replied by cogzoid on topic Solving some lingering F_error problems
I'm using limit3 because controlling the axis via g-codes makes for some really jerky movements as the motion controller tries to accurately control the motion of all of the axes at the same time. In other words, I don't want the complex arm movements to slow down because the bowtie is trying to spin around.
I haven't implemented the extra-joints patch that dgarrett wrote. There are parts of it I don't understand and so I'm trying to figure it out.
- Thank you received: 1472
19 Mar 2019 13:06 #128967
Replied by Todd Zuercher on topic Solving some lingering F_error problems
It might simply be a thread ordering problem, coupled with following error limits that are simply too tight for your servo system. Perhaps you should post your hal file(s)
- cogzoid
- Visitor
19 Mar 2019 19:12 #128990
by cogzoid
Sure thing, here's my .hal file as it is.
I am starting to implement dgarrett's extra-joints branch , so this might be a moot point.
# Generated by PNCconf at Tue Oct 30 16:21:02 2018
# overwritten when you run PNCconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES num_dio=16
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config="firmware=hm2/7i80/7i76e_7i76x1_7i85x1D.bit num_encoders=0 num_pwmgens=0 num_stepgens=9 sserial_port_0=00xxxx"
setp hm2_7i76e.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.a,pid.b,pid.c,pid.u,pid.v
loadrt limit3 names=limit3.a,limit3.b,limit3.c,limit3.u,limit3.v
loadrt sum2 names=sum2.a-cmd,sum2.b-cmd,sum2.c-cmd,sum2.u-cmd,sum2.v-cmd,sum2.a-fb,sum2.b-fb,sum2.c-fb,sum2.u-fb,sum2.v-fb
addf hm2_7i76e.0.read servo-thread
addf sum2.a-fb servo-thread
addf sum2.b-fb servo-thread
addf sum2.c-fb servo-thread
addf sum2.u-fb servo-thread
addf sum2.v-fb servo-thread
addf limit3.a servo-thread
addf limit3.b servo-thread
addf limit3.c servo-thread
addf limit3.u servo-thread
addf limit3.v servo-thread
addf sum2.a-cmd servo-thread
addf sum2.b-cmd servo-thread
addf sum2.c-cmd servo-thread
addf sum2.u-cmd servo-thread
addf sum2.v-cmd servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.a.do-pid-calcs servo-thread
addf pid.b.do-pid-calcs servo-thread
addf pid.c.do-pid-calcs servo-thread
addf pid.u.do-pid-calcs servo-thread
addf pid.v.do-pid-calcs servo-thread
addf hm2_7i76e.0.write servo-thread
setp hm2_7i76e.0.dpll.01.timer-us -50
setp hm2_7i76e.0.stepgen.timer-number 1
# external output signals
net dout-00 hm2_7i76e.0.7i76.0.0.output-00
net dout-01 hm2_7i76e.0.7i76.0.0.output-01
net dout-02 hm2_7i76e.0.7i76.0.0.output-02
net dout-03 hm2_7i76e.0.7i76.0.0.output-03
net dout-04 hm2_7i76e.0.7i76.0.0.output-04
net dout-05 hm2_7i76e.0.7i76.0.0.output-05
net dout-06 hm2_7i76e.0.7i76.0.0.output-06
net dout-07 hm2_7i76e.0.7i76.0.0.output-07
net dout-08 hm2_7i76e.0.7i76.0.0.output-08
net dout-09 hm2_7i76e.0.7i76.0.0.output-09
net dout-10 hm2_7i76e.0.7i76.0.0.output-10
net dout-11 hm2_7i76e.0.7i76.0.0.output-11
net dout-12 hm2_7i76e.0.7i76.0.0.output-12
# external input signals
net home-x <= hm2_7i76e.0.7i76.0.0.input-00
net home-y <= hm2_7i76e.0.7i76.0.0.input-01
net home-z <= hm2_7i76e.0.7i76.0.0.input-02
net home-a <= hm2_7i76e.0.7i76.0.0.input-03
net home-b <= hm2_7i76e.0.7i76.0.0.input-04
net home-c <= hm2_7i76e.0.7i76.0.0.input-05
net home-u <= hm2_7i76e.0.7i76.0.0.input-06
net home-v <= hm2_7i76e.0.7i76.0.0.input-07
# AXIS X -- Shoulder
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
setp pid.x.error-previous-target true
setp pid.x.maxerror .0005
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# Step Gen signals/setup
setp hm2_7i76e.0.stepgen.00.dirsetup [AXIS_0]DIRSETUP
setp hm2_7i76e.0.stepgen.00.dirhold [AXIS_0]DIRHOLD
setp hm2_7i76e.0.stepgen.00.steplen [AXIS_0]STEPLEN
setp hm2_7i76e.0.stepgen.00.stepspace [AXIS_0]STEPSPACE
setp hm2_7i76e.0.stepgen.00.position-scale [AXIS_0]STEP_SCALE
setp hm2_7i76e.0.stepgen.00.step_type 0
setp hm2_7i76e.0.stepgen.00.control-type 1
setp hm2_7i76e.0.stepgen.00.maxaccel [AXIS_0]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.00.maxvel [AXIS_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd <= axis.0.motor-pos-cmd
net x-vel-cmd <= axis.0.joint-vel-cmd
net x-output => hm2_7i76e.0.stepgen.00.velocity-cmd
net x-pos-fb <= hm2_7i76e.0.stepgen.00.position-fb
net x-pos-fb => axis.0.motor-pos-fb
net x-enable <= axis.0.amp-enable-out
net x-enable => hm2_7i76e.0.stepgen.00.enable
# ---setup home / limit switch signals---
net home-x => axis.0.home-sw-in
net x-neg-limit => axis.0.neg-lim-sw-in
net x-pos-limit => axis.0.pos-lim-sw-in
# AXIS Y - Elbow
setp pid.y.Pgain [AXIS_1]P
setp pid.y.Igain [AXIS_1]I
setp pid.y.Dgain [AXIS_1]D
setp pid.y.bias [AXIS_1]BIAS
setp pid.y.FF0 [AXIS_1]FF0
setp pid.y.FF1 [AXIS_1]FF1
setp pid.y.FF2 [AXIS_1]FF2
setp pid.y.deadband [AXIS_1]DEADBAND
setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT
setp pid.y.error-previous-target true
setp pid.y.maxerror .0005
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-vel-cmd => pid.y.command-deriv
net y-pos-fb => pid.y.feedback
net y-output => pid.y.output
setp hm2_7i76e.0.stepgen.01.dirsetup [AXIS_1]DIRSETUP
setp hm2_7i76e.0.stepgen.01.dirhold [AXIS_1]DIRHOLD
setp hm2_7i76e.0.stepgen.01.steplen [AXIS_1]STEPLEN
setp hm2_7i76e.0.stepgen.01.stepspace [AXIS_1]STEPSPACE
setp hm2_7i76e.0.stepgen.01.position-scale [AXIS_1]STEP_SCALE
setp hm2_7i76e.0.stepgen.01.step_type 0
setp hm2_7i76e.0.stepgen.01.control-type 1
setp hm2_7i76e.0.stepgen.01.maxaccel [AXIS_1]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.01.maxvel [AXIS_1]STEPGEN_MAXVEL
net y-pos-cmd <= axis.1.motor-pos-cmd
net y-vel-cmd <= axis.1.joint-vel-cmd
net y-output => hm2_7i76e.0.stepgen.01.velocity-cmd
net y-pos-fb <= hm2_7i76e.0.stepgen.01.position-fb
net y-pos-fb => axis.1.motor-pos-fb
net y-enable <= axis.1.amp-enable-out
net y-enable => hm2_7i76e.0.stepgen.01.enable
net home-y => axis.1.home-sw-in
net y-neg-limit => axis.1.neg-lim-sw-in
net y-pos-limit => axis.1.pos-lim-sw-in
# AXIS Z -- Wrist
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror .0005
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-vel-cmd => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
net z-output => pid.z.output
setp hm2_7i76e.0.stepgen.02.dirsetup [AXIS_2]DIRSETUP
setp hm2_7i76e.0.stepgen.02.dirhold [AXIS_2]DIRHOLD
setp hm2_7i76e.0.stepgen.02.steplen [AXIS_2]STEPLEN
setp hm2_7i76e.0.stepgen.02.stepspace [AXIS_2]STEPSPACE
setp hm2_7i76e.0.stepgen.02.position-scale [AXIS_2]STEP_SCALE
setp hm2_7i76e.0.stepgen.02.step_type 0
setp hm2_7i76e.0.stepgen.02.control-type 1
setp hm2_7i76e.0.stepgen.02.maxaccel [AXIS_2]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.02.maxvel [AXIS_2]STEPGEN_MAXVEL
net z-pos-cmd <= axis.2.motor-pos-cmd
net z-vel-cmd <= axis.2.joint-vel-cmd
net z-output => hm2_7i76e.0.stepgen.02.velocity-cmd
net z-pos-fb <= hm2_7i76e.0.stepgen.02.position-fb
net z-pos-fb => axis.2.motor-pos-fb
net z-enable <= axis.2.amp-enable-out
net z-enable => hm2_7i76e.0.stepgen.02.enable
net home-z => axis.2.home-sw-in
net z-neg-limit => axis.2.neg-lim-sw-in
net z-pos-limit => axis.2.pos-lim-sw-in
# AXIS A -- Ferris Wheel
setp limit3.a.maxv [AXIS_3]MAX_VELOCITY
setp limit3.a.maxa [AXIS_3]MAX_ACCELERATION
setp limit3.a.min [AXIS_3]MIN_LIMIT
setp limit3.a.max [AXIS_3]MAX_LIMIT
setp limit3.a.in 0 #this gets set to the target number by M110
setp pid.a.Pgain [AXIS_3]P
setp pid.a.Igain [AXIS_3]I
setp pid.a.Dgain [AXIS_3]D
setp pid.a.bias [AXIS_3]BIAS
setp pid.a.FF0 [AXIS_3]FF0
setp pid.a.FF1 [AXIS_3]FF1
setp pid.a.FF2 [AXIS_3]FF2
setp pid.a.deadband [AXIS_3]DEADBAND
setp pid.a.maxoutput [AXIS_3]MAX_OUTPUT
setp pid.a.error-previous-target true
setp pid.a.maxerror .0005
net a-index-enable <=> pid.a.index-enable
net a-enable => pid.a.enable
net a-pos-cmd => pid.a.command
net a-pos-fb0 => pid.a.feedback
net a-output => pid.a.output
setp hm2_7i76e.0.stepgen.03.dirsetup [AXIS_3]DIRSETUP
setp hm2_7i76e.0.stepgen.03.dirhold [AXIS_3]DIRHOLD
setp hm2_7i76e.0.stepgen.03.steplen [AXIS_3]STEPLEN
setp hm2_7i76e.0.stepgen.03.stepspace [AXIS_3]STEPSPACE
setp hm2_7i76e.0.stepgen.03.position-scale [AXIS_3]STEP_SCALE
setp hm2_7i76e.0.stepgen.03.step_type 0
setp hm2_7i76e.0.stepgen.03.control-type 1
setp hm2_7i76e.0.stepgen.03.maxaccel [AXIS_3]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.03.maxvel [AXIS_3]STEPGEN_MAXVEL
net a-pos-cmd-in0 sum2.a-cmd.in0 <= axis.3.motor-pos-cmd
net a-output => hm2_7i76e.0.stepgen.03.velocity-cmd
net a-pos-fb0 sum2.a-fb.in0 <= hm2_7i76e.0.stepgen.03.position-fb
net a-pos-fb-out => axis.3.motor-pos-fb
net a-enable <= axis.3.amp-enable-out
net a-enable => hm2_7i76e.0.stepgen.03.enable
# ---command summation math---
net limit-a-out sum2.a-cmd.in1 sum2.a-fb.in1 <= limit3.a.out
net a-pos-cmd <= sum2.a-cmd.out
# ---feedback subtraction math---
setp sum2.a-fb.gain1 -1.0 #subtract off limit3 signal
net a-pos-fb-out sum2.a-fb.out
net home-a => axis.3.home-sw-in
net a-neg-limit => axis.3.neg-lim-sw-in
net a-pos-limit => axis.3.pos-lim-sw-in
# AXIS B -- Tipper
setp limit3.b.maxv [AXIS_4]MAX_VELOCITY
setp limit3.b.maxa [AXIS_4]MAX_ACCELERATION
setp limit3.b.min [AXIS_4]MIN_LIMIT
setp limit3.b.max [AXIS_4]MAX_LIMIT
setp limit3.b.in 0 #this gets set to the target number by M120
setp pid.b.Pgain [AXIS_4]P
setp pid.b.Igain [AXIS_4]I
setp pid.b.Dgain [AXIS_4]D
setp pid.b.bias [AXIS_4]BIAS
setp pid.b.FF0 [AXIS_4]FF0
setp pid.b.FF1 [AXIS_4]FF1
setp pid.b.FF2 [AXIS_4]FF2
setp pid.b.deadband [AXIS_4]DEADBAND
setp pid.b.maxoutput [AXIS_4]MAX_OUTPUT
setp pid.b.error-previous-target true
setp pid.b.maxerror .0005
net b-index-enable <=> pid.b.index-enable
net b-enable => pid.b.enable
net b-pos-cmd => pid.b.command
net b-pos-fb0 => pid.b.feedback
net b-output => pid.b.output
setp hm2_7i76e.0.stepgen.04.dirsetup [AXIS_4]DIRSETUP
setp hm2_7i76e.0.stepgen.04.dirhold [AXIS_4]DIRHOLD
setp hm2_7i76e.0.stepgen.04.steplen [AXIS_4]STEPLEN
setp hm2_7i76e.0.stepgen.04.stepspace [AXIS_4]STEPSPACE
setp hm2_7i76e.0.stepgen.04.position-scale [AXIS_4]STEP_SCALE
setp hm2_7i76e.0.stepgen.04.step_type 0
setp hm2_7i76e.0.stepgen.04.control-type 1
setp hm2_7i76e.0.stepgen.04.maxaccel [AXIS_4]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.04.maxvel [AXIS_4]STEPGEN_MAXVEL
net b-pos-cmd-in0 sum2.b-cmd.in0 <= axis.4.motor-pos-cmd
net b-output => hm2_7i76e.0.stepgen.04.velocity-cmd
net b-pos-fb0 sum2.b-fb.in0 <= hm2_7i76e.0.stepgen.04.position-fb
net b-pos-fb-out => axis.4.motor-pos-fb
net b-enable <= axis.4.amp-enable-out
net b-enable => hm2_7i76e.0.stepgen.04.enable
net limit-b-out sum2.b-cmd.in1 sum2.b-fb.in1 <= limit3.b.out
net b-pos-cmd <= sum2.b-cmd.out
setp sum2.b-fb.gain1 -1.0 #subtract off limit3 signal
net b-pos-fb-out sum2.b-fb.out
net home-b => axis.4.home-sw-in
net b-neg-limit => axis.4.neg-lim-sw-in
net b-pos-limit => axis.4.pos-lim-sw-in
# AXIS C -- Shaker
setp limit3.c.maxv [AXIS_5]MAX_VELOCITY
setp limit3.c.maxa [AXIS_5]MAX_ACCELERATION
setp limit3.c.min [AXIS_5]MIN_LIMIT
setp limit3.c.max [AXIS_5]MAX_LIMIT
setp limit3.c.in 0 #this gets set to the target number by M130
setp pid.c.Pgain [AXIS_5]P
setp pid.c.Igain [AXIS_5]I
setp pid.c.Dgain [AXIS_5]D
setp pid.c.bias [AXIS_5]BIAS
setp pid.c.FF0 [AXIS_5]FF0
setp pid.c.FF1 [AXIS_5]FF1
setp pid.c.FF2 [AXIS_5]FF2
setp pid.c.deadband [AXIS_5]DEADBAND
setp pid.c.maxoutput [AXIS_5]MAX_OUTPUT
setp pid.c.error-previous-target true
setp pid.c.maxerror .0005
net c-index-enable <=> pid.c.index-enable
net c-enable => pid.c.enable
net c-pos-cmd => pid.c.command
net c-pos-fb0 => pid.c.feedback
net c-output => pid.c.output
setp hm2_7i76e.0.stepgen.05.dirsetup [AXIS_5]DIRSETUP
setp hm2_7i76e.0.stepgen.05.dirhold [AXIS_5]DIRHOLD
setp hm2_7i76e.0.stepgen.05.steplen [AXIS_5]STEPLEN
setp hm2_7i76e.0.stepgen.05.stepspace [AXIS_5]STEPSPACE
setp hm2_7i76e.0.stepgen.05.position-scale [AXIS_5]STEP_SCALE
setp hm2_7i76e.0.stepgen.05.step_type 0
setp hm2_7i76e.0.stepgen.05.control-type 1
setp hm2_7i76e.0.stepgen.05.maxaccel [AXIS_5]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.05.maxvel [AXIS_5]STEPGEN_MAXVEL
net c-pos-cmd-in0 sum2.c-cmd.in0 <= axis.5.motor-pos-cmd
net c-output => hm2_7i76e.0.stepgen.05.velocity-cmd
net c-pos-fb0 sum2.c-fb.in0 <= hm2_7i76e.0.stepgen.05.position-fb
net c-pos-fb-out => axis.5.motor-pos-fb
net c-enable <= axis.5.amp-enable-out
net c-enable => hm2_7i76e.0.stepgen.05.enable
net limit-c-out sum2.c-cmd.in1 sum2.c-fb.in1 <= limit3.c.out
net c-pos-cmd <= sum2.c-cmd.out
setp sum2.c-fb.gain1 -1.0 #subtract off limit3 signal
net c-pos-fb-out sum2.c-fb.out
net home-c => axis.5.home-sw-in
net c-neg-limit => axis.5.neg-lim-sw-in
net c-pos-limit => axis.5.pos-lim-sw-in
# AXIS U -- EyeLean
setp limit3.u.maxv [AXIS_6]MAX_VELOCITY
setp limit3.u.maxa [AXIS_6]MAX_ACCELERATION
setp limit3.u.min [AXIS_6]MIN_LIMIT
setp limit3.u.max [AXIS_6]MAX_LIMIT
setp limit3.u.in 0 #this gets set to the target number by M140
setp pid.u.Pgain [AXIS_6]P
setp pid.u.Igain [AXIS_6]I
setp pid.u.Dgain [AXIS_6]D
setp pid.u.bias [AXIS_6]BIAS
setp pid.u.FF0 [AXIS_6]FF0
setp pid.u.FF1 [AXIS_6]FF1
setp pid.u.FF2 [AXIS_6]FF2
setp pid.u.deadband [AXIS_6]DEADBAND
setp pid.u.maxoutput [AXIS_6]MAX_OUTPUT
setp pid.u.error-previous-target true
setp pid.u.maxerror .0005
net u-index-enable <=> pid.u.index-enable
net u-enable => pid.u.enable
net u-pos-cmd => pid.u.command
net u-pos-fb0 => pid.u.feedback
net u-output => pid.u.output
setp hm2_7i76e.0.stepgen.06.dirsetup [AXIS_6]DIRSETUP
setp hm2_7i76e.0.stepgen.06.dirhold [AXIS_6]DIRHOLD
setp hm2_7i76e.0.stepgen.06.steplen [AXIS_6]STEPLEN
setp hm2_7i76e.0.stepgen.06.stepspace [AXIS_6]STEPSPACE
setp hm2_7i76e.0.stepgen.06.position-scale [AXIS_6]STEP_SCALE
setp hm2_7i76e.0.stepgen.06.step_type 0
setp hm2_7i76e.0.stepgen.06.control-type 1
setp hm2_7i76e.0.stepgen.06.maxaccel [AXIS_6]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.06.maxvel [AXIS_6]STEPGEN_MAXVEL
net u-pos-cmd-in0 sum2.u-cmd.in0 <= axis.6.motor-pos-cmd
net u-output => hm2_7i76e.0.stepgen.06.velocity-cmd
net u-pos-fb0 sum2.u-fb.in0 <= hm2_7i76e.0.stepgen.06.position-fb
net u-pos-fb-out => axis.6.motor-pos-fb
net u-enable <= axis.6.amp-enable-out
net u-enable => hm2_7i76e.0.stepgen.06.enable
net limit-u-out sum2.u-cmd.in1 sum2.u-fb.in1 <= limit3.u.out
net u-pos-cmd <= sum2.u-cmd.out
setp sum2.u-fb.gain1 -1.0 #subtract off limit3 signal
net u-pos-fb-out sum2.u-fb.out
net home-u => axis.6.home-sw-in
net u-neg-limit => axis.6.neg-lim-sw-in
net u-pos-limit => axis.6.pos-lim-sw-in
# AXIS V -- Bowtie
setp limit3.v.maxv [AXIS_7]MAX_VELOCITY
setp limit3.v.maxa [AXIS_7]MAX_ACCELERATION
setp limit3.v.min [AXIS_7]MIN_LIMIT
setp limit3.v.max [AXIS_7]MAX_LIMIT
setp limit3.v.in 0 #this gets set to the target number by M140
setp pid.v.Pgain [AXIS_7]P
setp pid.v.Igain [AXIS_7]I
setp pid.v.Dgain [AXIS_7]D
setp pid.v.bias [AXIS_7]BIAS
setp pid.v.FF0 [AXIS_7]FF0
setp pid.v.FF1 [AXIS_7]FF1
setp pid.v.FF2 [AXIS_7]FF2
setp pid.v.deadband [AXIS_7]DEADBAND
setp pid.v.maxoutput [AXIS_7]MAX_OUTPUT
setp pid.v.error-previous-target true
setp pid.v.maxerror .0005
net v-index-enable <=> pid.v.index-enable
net v-enable => pid.v.enable
net v-pos-cmd => pid.v.command
net v-pos-fb0 => pid.v.feedback
net v-output => pid.v.output
setp hm2_7i76e.0.stepgen.07.dirsetup [AXIS_7]DIRSETUP
setp hm2_7i76e.0.stepgen.07.dirhold [AXIS_7]DIRHOLD
setp hm2_7i76e.0.stepgen.07.steplen [AXIS_7]STEPLEN
setp hm2_7i76e.0.stepgen.07.stepspace [AXIS_7]STEPSPACE
setp hm2_7i76e.0.stepgen.07.position-scale [AXIS_7]STEP_SCALE
setp hm2_7i76e.0.stepgen.07.step_type 0
setp hm2_7i76e.0.stepgen.07.control-type 1 #PID control => 1
setp hm2_7i76e.0.stepgen.07.maxaccel [AXIS_7]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.07.maxvel [AXIS_7]STEPGEN_MAXVEL
net v-pos-cmd-in0 sum2.v-cmd.in0 <= axis.7.motor-pos-cmd
net v-output => hm2_7i76e.0.stepgen.07.velocity-cmd
net v-pos-fb0 sum2.v-fb.in0 <= hm2_7i76e.0.stepgen.07.position-fb
net v-pos-fb-out => axis.7.motor-pos-fb
net v-enable <= axis.7.amp-enable-out
net v-enable => hm2_7i76e.0.stepgen.07.enable
net limit-v-out sum2.v-cmd.in1 sum2.v-fb.in1 <= limit3.v.out
net v-pos-cmd <= sum2.v-cmd.out
setp sum2.v-fb.gain1 -1.0 #subtract off limit3 signal
net v-pos-fb-out sum2.v-fb.out
net home-v => axis.7.home-sw-in
net v-neg-limit => axis.7.neg-lim-sw-in
net v-pos-limit => axis.7.pos-lim-sw-in
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.jog.0.plus
net jog-x-neg halui.jog.0.minus
net jog-x-analog halui.jog.0.analog
net joint-select-b halui.joint.1.select
net y-is-homed halui.joint.1.is-homed
net jog-y-pos halui.jog.1.plus
net jog-y-neg halui.jog.1.minus
net jog-y-analog halui.jog.1.analog
net joint-select-c halui.joint.2.select
net z-is-homed halui.joint.2.is-homed
net jog-z-pos halui.jog.2.plus
net jog-z-neg halui.jog.2.minus
net jog-z-analog halui.jog.2.analog
net joint-select-d halui.joint.3.select
net a-is-homed halui.joint.3.is-homed
net jog-a-pos halui.jog.3.plus
net jog-a-neg halui.jog.3.minus
net jog-a-analog halui.jog.3.analog
net joint-select-e halui.joint.4.select
net b-is-homed halui.joint.4.is-homed
net jog-b-pos halui.jog.4.plus
net jog-b-neg halui.jog.4.minus
net jog-b-analog halui.jog.4.analog
net joint-select-f halui.joint.5.select
net c-is-homed halui.joint.5.is-homed
net jog-c-pos halui.jog.5.plus
net jog-c-neg halui.jog.5.minus
net jog-c-analog halui.jog.5.analog
net joint-select-g halui.joint.6.select
net u-is-homed halui.joint.6.is-homed
net jog-u-pos halui.jog.6.plus
net jog-u-neg halui.jog.6.minus
net jog-u-analog halui.jog.6.analog
net joint-select-h halui.joint.7.select
net v-is-homed halui.joint.7.is-homed
net jog-v-pos halui.jog.7.plus
net jog-v-neg halui.jog.7.minus
net jog-v-analog halui.jog.7.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net machine-is-on halui.machine.is-on
net jog-speed halui.jog-speed
net MDI-mode halui.mode.is-mdi
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# Outputs:
# 3 for pneumatics
# 1 for motor
# 6 pumps
# 3 light show
# Inputs:
# 8 Home Switch inputs
# 1 E-stop input
net dout-00 <= motion.digital-out-00
net dout-01 <= motion.digital-out-01
net dout-02 <= motion.digital-out-02
net dout-03 <= motion.digital-out-03
net dout-04 <= motion.digital-out-04
net dout-05 <= motion.digital-out-05
net dout-06 <= motion.digital-out-06
net dout-07 <= motion.digital-out-07
net dout-08 <= motion.digital-out-08
net dout-09 <= motion.digital-out-09
net dout-10 <= motion.digital-out-10
net dout-11 <= motion.digital-out-11
net dout-12 <= motion.digital-out-12
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# --- ESTOP-EXT ---
#net estop-ext <= hm2_7i76e.0.7i76.0.0.input-04
#net estop-ext => iocontrol.0.emc-enable-inI am starting to implement dgarrett's extra-joints branch , so this might be a moot point.
19 Mar 2019 20:08 #128993
Don't know if it would make a difference. Have you tried to use Hal's offset component instead of using two sum2s?
linuxcnc.org/docs/html/man/man9/offset.9.html
It would at least make your hal file a little cleaner, and your fb sum2 is using the limit3 value from the previous servo thread cycle. But that may or may not matter. Some Halscope traces when the following error alarm trips probably would be enlightening.
The following user(s) said Thank You: cogzoid
- cogzoid
- Visitor
19 Mar 2019 20:48 #128998
by cogzoid
Oh geeze, that looks like the perfect component for my situation. Thanks for pointing that out! I can definitely clean up my hal file with that. I'm going to try utilizing dgarrett's approach first, though. Thanks!
Time to create page: 0.156 seconds
