Building simulator version off master
- bevins
- Thank you received: 338
26 Mar 2019 15:06 - 26 Mar 2019 15:14 #129695
by bevins
Replied by bevins on topic Building simulator version off master
ok made it through alive.
Compiling now......
FAILED:
collect2: error: ld returned 1 exit status
emc/usr_intf/axis/Submakefile:25: recipe for target '../lib/python/_togl.so' failed
make: *** [../lib/python/_togl.so] Error 1
Compiling now......
FAILED:
Last edit: 26 Mar 2019 15:14 by bevins.
- bevins
26 Mar 2019 16:24 #129704
by bevins
ok, finally got everything worked out and it running......whew......
- AnnoyingMutt
- Visitor
26 Mar 2019 18:16 #129716
by AnnoyingMutt
Replied by AnnoyingMutt on topic Building simulator version off master
Did you read the link I gave with the notes ?
It covered all your issues
- Online
- Thank you received: 7471
27 Mar 2019 00:02 #129737
Replied by tommylight on topic Building simulator version off master
LinuxMint 19.1 on this laptop, compiled the kernel, restarted, downloaded the stretch master deb from buildbot, installed with gdebi. That is it.
Usually i use a precompiled kernel from the main computer also, but i had an older version so i had to compile it.
- Thank you received: 4652
27 Mar 2019 11:03 #129757
Replied by andypugh on topic Building simulator version off master
You can run a uspace build as a sim on an un-patched normal kernel.
- bevins
27 Mar 2019 11:31 #129761
by bevins
Thats what I am doing. Worked yesterday, but today cannot find the linuxcnc command...lol
- AnnoyingMutt
- Visitor
27 Mar 2019 11:33 #129763
by AnnoyingMutt
In your linuxcnc-dev directory
cd ../scripts
. ./rip-environment
(note it is dot space dot/rip-environment)
linuxcnc
Seriously dude check the links to the notes I gave...it's all there
cd ../scripts
. ./rip-environment
linuxcnc
- bevins
27 Mar 2019 11:44 #129767
by bevins
yeah yeah I forgot about running it that way. but to your point, it is not all there. It's missing about two hours of searching and finding and installing dependencies.
cd ../scripts
. ./rip-environment
linuxcnc
sSeriously dude check the links to the notes I gave...it's all there
- AnnoyingMutt
- Visitor
27 Mar 2019 11:58 #129769
by AnnoyingMutt
What was missing ?
When myself and Don ran through it it was all good. ( Apart from few typos which were fixed)
The boost::python headers required & "--enable-non-distributable=yes" things were covered.
- bevins
27 Mar 2019 12:07 - 27 Mar 2019 12:09 #129770
by bevins
AH, sorry man. Didn't see that post. Thought you were talking about the Github link.
Would have been alot easier. But I wouldnt have learned as much.
What was missing ?
dnt see the boost::python headers required & "--enable-non-distributable=yes" things were covered.
Last edit: 27 Mar 2019 12:09 by bevins.
Time to create page: 0.259 seconds
