Building simulator version off master
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
26 Mar 2019 12:05 #129671 by bevins
Is there any docs on how to build simulator version of master from git? I am looking but cannot find any
  • Moderator
  • Moderator
26 Mar 2019 12:26 #129673 by tommylight
Replied by tommylight on topic Building simulator version off master
Try one of the ready made deb's first, here
buildbot.linuxcnc.org/dists/
I never had to build a simulator, usually one of deb's works, depending on the distro you are using.
It saves a lot of time and nerves.
Look for master-sim folders
  • AnnoyingMutt
  • AnnoyingMutt's Avatar
  • Visitor
  • Visitor
26 Mar 2019 12:48 #129677 by AnnoyingMutt
Replied by AnnoyingMutt on topic Building simulator version off master
github.com/LinuxCNC/linuxcnc/blob/master/docs/INSTALL
The uspace option will build without a rt kernel, is that what you're thinking of ?
  • bevins
  • Platinum Member
  • Platinum Member
26 Mar 2019 12:51 #129678 by bevins
Replied by bevins on topic Building simulator version off master
I am on linuxmint 19.
  • bevins
  • Platinum Member
  • Platinum Member
26 Mar 2019 12:52 #129679 by bevins
I just want something I can run to test some stuff. I am tired of testing on production machines, and hoping all goes well.
  • AnnoyingMutt
  • Visitor
  • Visitor
26 Mar 2019 12:54 #129681 by AnnoyingMutt
I wrote some quick notes here:
forum.linuxcnc.org/9-installing-linuxcnc...xcnc?start=30#129459
Instructions for Ubuntu 18.04 but should be good for Mint as well.
  • AnnoyingMutt
  • Visitor
  • Visitor
26 Mar 2019 12:55 #129682 by AnnoyingMutt
Have a read of the link I gave, should answer your questions.
  • bevins
  • Platinum Member
  • Platinum Member
26 Mar 2019 14:16 #129686 by bevins
configure: WARNING: The LinuxCNC binary you are building may not be
distributable due to a license incompatibility with LinuxCNC (some portions
GPL-2 only) and Readline version 6 and greater (GPL-3 or later).
What is that? followed by:
configure: error: To configure LinuxCNC in this way, you must
invoke configure with "--enable-non-distributable=yes". Note that on
Debian-based systems, you may be able to use libreadline-gplv2-dev instead.
  • bevins
  • Platinum Member
  • Platinum Member
26 Mar 2019 14:28 #129687 by bevins
Stuck in dependency Hell............
  • bevins
  • Platinum Member
  • Platinum Member
26 Mar 2019 14:43 - 26 Mar 2019 14:44 #129691 by bevins
boost::python headers required
Stuck here........ anyone know the package name?
Last edit: 26 Mar 2019 14:44 by bevins.
Time to create page: 1.352 seconds
