Need help installing LinuxCNC
- AnnoyingMutt
- Visitor
24 Mar 2019 08:18 #129453
by AnnoyingMutt
Replied by AnnoyingMutt on topic Need help installing LinuxCNC
If you want to use a linuxcnc install image maybe just buy a seperate NIC. If of course you have a spare slot
- AnnoyingMutt
- Visitor
24 Mar 2019 09:25 - 24 Mar 2019 21:18 #129459
by AnnoyingMutt
To build on Ubuntu 18.04.1
In your terminal:
I just installed Ubuntu 18.04.1 in virtualbox and went through the process. Just to check.
In your terminal:
sudo apt install devscripts build-essential imagemagick tcl8.6-dev tk8.6-dev libxaw7-dev libncurses-dev python-dev python-tk libglu1-mesa-dev libgtk2.0-dev source-highlight libboost-python-dev debhelper libmodbus-dev dvipng libusb-1.0-0-dev inkscape python-numpy python-imaging-tk python-gtkglext1 blt bwidget libtk-img tclx libudev-dev python-vte libqt4-dev libssl-dev libxenomai-dev git python-pil.imagetk
(The above has to be on one line)
sudo apt install yapps2 intltool libreadline-dev git
cd ~
git clone https://github.com/LinuxCNC/linuxcnc.git linuxcnc-dev
cd linuxcnc-dev/src
./autogen.sh
./configure --with-realtime=uspace --enable-non-distributable=yes
make
sudo make setuid
cd ../scripts
. ./rip-environment
(note it is dot space dot/rip-environment)
linuxcncI just installed Ubuntu 18.04.1 in virtualbox and went through the process. Just to check.
Last edit: 24 Mar 2019 21:18 by AnnoyingMutt. Reason: added code tags, fix configure
- hvnfun2
24 Mar 2019 17:12 #129493
by hvnfun2
Replied by hvnfun2 on topic Need help installing LinuxCNC
I ran into trouble with the second command. Got an error on initltool.
Processing triggers for tex-common (6.09) ...
Running updmap-sys. This may take some time... done.
Running mktexlsr /var/lib/texmf ... done.
Building format(s) --all.
don@don-PRIME-Z390-A:~$ sudo apt install yapps2 initltool libreadline-dev git
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package initltool
- AnnoyingMutt
- Visitor
24 Mar 2019 18:22 - 24 Mar 2019 18:24 #129495
by AnnoyingMutt
Sorry my bad stupid typo
the package you want is intltool
the original post has been edited to suit
Last edit: 24 Mar 2019 18:24 by AnnoyingMutt.
- hvnfun2
24 Mar 2019 18:40 #129497
by hvnfun2
Thanks... that command worked... now have another problem
don@don-PRIME-Z390-A:~$ cd ~
don@don-PRIME-Z390-A:~$ git clone github.com/LinuxCNC/linuxcnc.git linuxcnc-dev
fatal: repository 'github.com/LinuxCNC/linuxcnc.git' does not exist
is that what I should use?
- Thank you received: 7490
24 Mar 2019 19:03 #129498
Replied by tommylight on topic Need help installing LinuxCNC
The stretch version of 2.8 ( master ) works in LinuxMint19.1 as is !
Literally download, open with gdebi, click install ! That is with Preempt-RT .
Sim should also work without preempt-rt.
- AnnoyingMutt
- Visitor
24 Mar 2019 19:31 - 24 Mar 2019 19:32 #129508
by AnnoyingMutt
Another typo
Original has been edited as well
git clone https://github.com/LinuxCNC/linuxcnc.git linuxcnc-devOriginal has been edited as well
Last edit: 24 Mar 2019 19:32 by AnnoyingMutt.
- AnnoyingMutt
- Visitor
24 Mar 2019 19:37 #129511
by AnnoyingMutt
I think I have a solution to your card not being recognised with the Debian net install.
Found the updated driver source and compiled it, it should recognise your card, would have to make some packages for you to install once the install is completed.
- hvnfun2
24 Mar 2019 21:13 #129518
by hvnfun2
Thanks Tommylight with your input. i will give that a try when I get a chance.
I believe I found another typo in that install post. The command as given is
./confiure --with-realtime=uspace --enable-non-distributable=yes
I think it should be
If you concur it would be good to edit the post for future reference.
With that change I was able to finish the installation and start linuxcnc YEAH!!!
Thanks so much for everyone's help
If you think you have a solution for the network card I would be glad to give that another go.
- AnnoyingMutt
- Visitor
24 Mar 2019 21:27 #129520
by AnnoyingMutt
Yeah you got it to work, even after my dopey typos.
I'll have to run through the process a few times to nail it down.
Time to create page: 0.190 seconds
