Joint following error on stepper system
  • screwtop
  • screwtop's Avatar Topic Author
  • New Member
  • New Member
28 Apr 2019 18:38 #132206 by screwtop
Replied by screwtop on topic Joint following error on stepper system
That's an interesting suggestion, thanks. I hadn't considered changing the microstepping as 400 steps/mm is how it was configured from the factory (it's a Chinese-made router with 600 mm x 900 mm bed, stepper-driven leadscrews on all three axes). The 20,000 ns BASE_PERIOD was about as low as I could go reliably, so it might be good to have a bit more headroom there while still achieving good speeds and adequate precision and smoothness.
(As it happens, one of the main reasons for converting the machine to LinuxCNC control was that the original hand-held controller had similar problems with these engraving jobs, and also had annoying limits on the size of G-code it would run. I was impressed that LinuxCNC using PC parallel port could achieve higher step frequencies than the factory controller with DSP!)
  • screwtop
  • New Member
  • New Member
28 Apr 2019 21:57 #132234 by screwtop
Reflecting on increasing the following-error limits, I'd still like to leave them at some reasonable value, since the errors were pointing to a significant problem (even if it wasn't actually exceeding stepgen's frequency limits). I'm still not 100% sure what a "reasonable" value would be, though - it seems that the expected f-error increases with the speed of motion, and might depend on other variables too.
29 Apr 2019 01:26 #132242 by pl7i92
Replied by pl7i92 on topic Joint following error on stepper system
what values of speed are you using
40mm/sec following error 1 is ok
80mm/sec 2 is best
120mm/sec i go for 2.5
i got 120000 base period at 100Steps/mm SCALE
Nema24 4Nm steppers at 250kg Gantry Rack pinion
15 Mar 2023 02:18 #266727 by smeet
Replied by smeet on topic Joint following error on stepper system
i am not sure what worng i am doing i tried to setup a 5axis head head cnc here are my ini files and hal files
i get a joint following error on g code
G0 B90
Thankyou for your help
15 Mar 2023 07:29 #266746 by andypugh
Replied by andypugh on topic Joint following error on stepper system
You have resurrected a very old thread here. But the only reason that you can have a following-error with a stepper system is if the system simply can't emit enough steps to follow the requested velocity. This can be caused by step length too long or base thread too slow (if you are using software stepping)
You have a base thread of 100,000 ns so can step at 10kHz
The G-code line that causes the problem is well within the B-axis limits, but which axis is the f-error on? My guess is that (because of the 5axis kinematics) the B-move is requiring a very rapid move of another axis (faster than the system can generate steps) and that is triggering the f-error.
Unfortunately LinuxCNC does not know how to limit the speed of an axis that is inside its limits to keep an axis that is moving separately as a result of kinematics inside its limits.
(If both axes are commanded to move in the same G-code line then it limits to the slowest)
You could either limit the B-move to a speed that the other axes can follow, or possibly add a move of the dependent axes to that move so that their position in real space (rather than in TCP space) remains approximately constant)
I have long wished to fix this, I even think I know how, but have never found the time when it was near enough the top of the pile.
15 Mar 2023 07:46 #266747 by smeet
it was on joint 0 following error
15 Mar 2023 07:49 #266748 by andypugh
OK, so the X axis is trying to make a long, fast move to stay at the same position in TCP space, and can't quite follow fast enough.
If you convert that G0 to a high-feedrate G1 (or make the move with the tool closer to the work, if it is retracted) then it might work.
15 Mar 2023 12:42 #266770 by smeet
in that case if i reduce the velocity of b axis and c axis it should work in that therory
16 Mar 2023 02:35 #266807 by smeet
here i am attaching my files if someone can help me figure out what error i am making i am not sure whats wrong thankyou for you help
  • Aciera
  • Aciera's Avatar
  • Administrator
  • Administrator
16 Mar 2023 03:31 - 16 Mar 2023 03:47 #266810 by Aciera
Replied by Aciera on topic Joint following error on stepper system
It's generally a good idea to give an update of what you have changed and what is (still) not working.
Looking at your hal and ini files it looks like you lowered the base thread and also lowered the angular joint maximum velocities. I presume you are still getting joint0 following errors when moving the B axis?. Also the pivot length setting seems to have disappeared?
Have you tried lowering the Baxis/joint velocities further?
You have set a max velocity of 25°/s for the angular B axis with a pivot length + tool length of say 100mm.
A command of G0 B25 will thus result in a TCP displacement in the x direction of tan(25)*100=46.6mm (ie the x-axis has a required velocity of at least 46.6mm/s )
This explains the joint0 following error since your joint0 has a max velocity of 25mm/s.
If your joint0 can really only go 25mm/s your B axis can only move as fast as:
0.8*atan(25/100)=11°/s (the factor 0.8 allows for 20% head room for step generation)
Note that this will decrease further if your pivot length + tool length is more than 100mm.
Similarly you would need to check the axis/joint max acceleration values.
[edit]
Of course the same goes for the other two (y,z) linear axis/joint velocities/accelerations and also the c angular axis/joint
Last edit: 16 Mar 2023 03:47 by Aciera.
Time to create page: 1.328 seconds
