Change acceleration on the fly?
15 Feb 2025 08:42 #321641 by Aciera
Replied by Aciera on topic Change acceleration on the fly?
Yes, I did those chanes in gcode file, but that need to be fixed before we start the machining. Looking for run time solutions, like mentioned with the button push the accelaration should be change with the feed rate.
When I say 'change feed rate in real time' I don't mean the feed rate settings in the gcode I mean using a hal pin to change the current feed rate set in the gcode (ie feedrate override). You can slow it down to a stand still and even make it run backwards.
24 Feb 2025 08:25 #322489 by urvilsuthar
Replied by urvilsuthar on topic Change acceleration on the fly?
I hope this message finds you well. the issue with my machine's feedrate and acceleration settings while using the Python module's feedrate function. Despite initially lowering the feedrate, I am still encountering problems where the machine achieve speed of 1500mm/min on short segments during 2D movements. This has led to some safety concerns, as the spindle has accidentally hit me on the head due to these high speeds.
To resolve this, I am trying to implement a feature where, upon pressing a push button, the machine would operate at just 10% of its maximum speed and adjust the acceleration to 10% of the set maximum acceleration, to tackle the 2D sort segment speed up very slow, with a hop i do not hit me again.
24 Feb 2025 08:59 #322494 by Aciera
using the python interface for on the fly feedrate changes is a bad idea that is what the real time 'motion' pins are for:
linuxcnc.org/docs/html/man/man9/motion.9.html
24 Feb 2025 09:29 #322496 by urvilsuthar
Hello Rodw,
I tried offset concept with the current system, but at the end fallback to the same thing happening previously.
I have added the hal files and opratated the system, when start eoffset and changing the accelaration the accelaration changes only on Z axis level offset movement only, but this did not affect the possible speed variation on the other axis, can be increase or decreased.
also modified (attached) the eoffset hal file and xml file to set the acceleration dynamically but the reasult the small files get buffered in the queue by emctaskplan calls and the velocity/accel change commands never get executed, also shared the log file..
24 Feb 2025 11:43 - 26 Feb 2025 03:28 #322510 by urvilsuthar
Thank you Aciera for sharing tips, will definitely convert it to motion pins.
I have gone thrugh the motion section pins in  linuxcnc.org/docs/html/man/man9/motion.9.html , but i am unable to find the feed override inputs. can you please share more details on this...
Last edit: 26 Feb 2025 03:28 by urvilsuthar.
Time to create page: 0.445 seconds
