New Plasma - stepper or servo for Z
- bevins
- Thank you received: 338
15 May 2019 19:08 - 15 May 2019 19:09 #133883
by bevins
New Plasma - stepper or servo for Z was created by bevins
I am in the process of ordering parts for a new machine I am building.
With Plasmac. would it be better to use a stepper or servo for the Z, and why?
I am using servos for X and Y
I will be using 5i25-7i77 with a thcad card
Thanks Bob
Thanks Bob
Last edit: 15 May 2019 19:09 by bevins.
- Thank you received: 5321
15 May 2019 19:43 #133887
Replied by PCW on topic New Plasma - stepper or servo for Z
I suspect you would be better off with a 7I92M+7I77 for EMI reasons
_if_ the PC is not built into the same box as the 7I77
- bevins
15 May 2019 19:57 #133895
by bevins
The PC is in the metal console with the 7i77. I am reluctant in trying the ethernet modules. I've always used 5i25 and have never ever had a problem. They just work....
Replied by bevins on topic New Plasma - stepper or servo for Z
15 May 2019 20:21 - 15 May 2019 20:21 #133899
Overall we have had fewer problems with Ethernet cards than PCI,
mainly related to dirty PCI contacts ( user plugs PCI card into slot of old PC
that has been vacant and accumulating grime for 10 years... )
Last edit: 15 May 2019 20:21 by PCW.
- bevins
15 May 2019 21:27 #133920
by bevins
OK, turns out the same price as plug n go kit when you buy the db25 cable.
Will have to buy a nic card though also. Not mentioning compiling, which I don't have alot of luck with....lol
I have a few days to think about it before I order.
15 May 2019 21:32 #133922
If the 7I77/connecting cable is in the same box, there's not as much
advantage in using Ethernet.
Where its nice is when the PC is in a control panel some distance
from the drive/electronics box
You should not need to compile anything to use Ethernet (just use the Stretch.LinuxCNC ISO)
- islander261
- Thank you received: 216
16 May 2019 03:10 #133940
by islander261
Replied by islander261 on topic New Plasma - stepper or servo for Z
Ok, I think your reasoning is sound for most CNC machines. For plasma you want all the isolation you can get between the table and your control computer. I realize PCW, the inventor of the Mesa cards, may differ but for plasma use an Ethernet card with its's own power supply! I have never had a hiccup with my 7i76E and the only other thing I have is a THCad card some relays and a couple of opto modules. Full limit and combined homing switches, float switch and ohmic probing. I still have more I/O points available left over than I know what to do with. Full disclosure I also have a USB pendant that also works well for me.
- Thank you received: 4144
16 May 2019 08:20 - 16 May 2019 08:22 #133954
Replied by rodw on topic New Plasma - stepper or servo for Z
I think if I was working with servos, I'd use one on the Z as well. I use a 7i76e and unlike John, I've used just about every input on it. I think I've got about one left. Mainly becasue I chose to use a wireless pendant with a receiver in the control panel and seperate home min and max limits on every joint.
You don't say what plasma cutter, how big the table is and if its HF start or not. My neighbour at work has a new HF start Hypertherm 200amp machine and commercial table and has been plagued by problems with his arcOK circuit faulting and stopping cutting due to what my resident HF electronics expert says is due to basic design faults that a $17 part could fix. Thats why I like the ethernet cards..... and the plasmac ohmic sensing circuit that Islander designed.
Last edit: 16 May 2019 08:22 by rodw.
- AgentWD40
- Thank you received: 96
16 May 2019 15:15 #133982
by AgentWD40
Replied by AgentWD40 on topic New Plasma - stepper or servo for Z
Rod, do you have a link to Islander's ohmic sensing circuit?
- bevins
16 May 2019 17:34 #133989
by bevins
Its a 5X11 water table I am building and I will be using Hyperterm 105 with the CNC torch.
I'd be interested in looking up the ohmic sensor you used.
Time to create page: 0.133 seconds
