external start
- phoenix
18 May 2019 03:09 #134095
by phoenix
external start was created by phoenix
i need external start button in my program what files do i need to configure in order to do that
- Thank you received: 4141
18 May 2019 06:47 #134103
Replied by rodw on topic external start
Halui is your friend. Check the docs but try halui.machine.on
- phoenix
18 May 2019 06:58 #134106
by phoenix
Replied by phoenix on topic external start
I need more help than that i dont know anything about hal
OR JUST TELL ME WHICH FILES I NEED TO CONFIGURE AND ILL FIGURE IT OUT
- pl7i92
- Thank you received: 358
18 May 2019 09:11 - 18 May 2019 09:24 #134120
by pl7i92
Replied by pl7i92 on topic external start
in the INI of your mashine
enable in HAL section POSTGUIFILE
# Single file that is executed after the GUI has started. Only supported by
# AXIS at this time (only AXIS creates a HAL component of its own)
POSTGUI_HALFILE = mtest_postgui.hal
HALUI = halui
THEN in the postgui FILE
# External Mashine on
net ext-mashine-on halui.machine.on <= YOUR PIN
video to do it Axis button
infos here
linuxcnc.org/docs/html/man/man1/halui.1.html
IF you tell us here where and how did you connect your button
we can give you the clear and correct command to put in postgui file
HALUI = halui
infos here
Last edit: 18 May 2019 09:24 by pl7i92. Reason: Video
The following user(s) said Thank You: phoenix
- phoenix
18 May 2019 09:38 #134134
by phoenix
sir i connected that button to parport.0.15.in
i.e. pin no 15 on my parellal port
- pl7i92
18 May 2019 09:40 #134136
by pl7i92
thanks
then its
net ext-mashine-on halui.machine.on <= parport.0.pin-15-in
then its
- phoenix
18 May 2019 09:46 #134139
by phoenix
i added that line to my filename.hal axis starts without errror but button not doing anything
i have push button connected to pin 15
- pl7i92
18 May 2019 09:48 #134142
by pl7i92
can you please post the ini and Halfile
i guess you dident do what we talked about
there is to be a new HAL file inside your mashine Folder
- phoenix
18 May 2019 09:54 #134145
by phoenix
these are my files
thanks buddy your help is greatly appreciated
these are my files
- phoenix
18 May 2019 10:05 #134149
by phoenix
i need help qickly
Time to create page: 0.251 seconds
