Latency problems on a fairly recent PC
19 May 2019 22:17 #134293 by petmakris
Latency problems on a fairly recent PC was created by petmakris
I have and old PC with the following CPU and onboard Graphics
- Intel Core2 Quad CPU Q6600 @2.4GHz
- NVIDIA Corporation C73 [GeForce 7100 / nForce 630i] (rev a2)
The motherboard is Gigabyte GA-73PVM-S2H (www.gigabyte.com/Motherboard/GA-73PVM-S2H-rev-10#ov)
According to what I read I should be getting low Jitter but I get
Max Jitter (1ms thread)
423122 (ns)
Max Jitter (25μs thread)
21171 (ns)
Before trying an external PCI-e graphics card (I can't any laying around) to see if improves latency, what else should I try?
Isn't this jitter too large for this setup?
I installed Debian Wheezy as is. No configuration at all on the machine.
uname -a prompts:
Linux cnc1 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686  GNU/Linux
19 May 2019 23:56 #134307 by andypugh
Replied by andypugh on topic Latency problems on a fairly recent PC
That's horrible latency.
Might be worth trying latency-histogram to see if it is a single huge value every once in a while.
Possibly SMI?
  • Moderator
  • Moderator
20 May 2019 00:03 #134309 by tommylight
Replied by tommylight on topic Latency problems on a fairly recent PC
Have you disabled everything not needed in BIOS?
Absolutely disable hyper threading and speed step and sleep modes and everything pertaining to power saving, including pci-e power saving, serial at a power saving etc.
Find an ATI or AMD graphic card, as you can not disable power saving for nvidia cards.
20 May 2019 00:14 - 20 May 2019 00:14 #134311 by petmakris
Replied by petmakris on topic Latency problems on a fairly recent PC
Thanks for the reply.
I will just do what you propose in the BIOS (I am running optimum defaults).
Also I found an Asus Radeon HD7770 1GB to test out.
Last edit: 20 May 2019 00:14 by petmakris.
20 May 2019 00:21 - 20 May 2019 00:31 #134313 by petmakris
Does this histogram screen-shot tells you anything? I am not sure what I am watching.
Last edit: 20 May 2019 00:31 by petmakris.
20 May 2019 00:38 #134314 by petmakris
And moments later
20 May 2019 01:39 #134317 by PCW
Replied by PCW on topic Latency problems on a fairly recent PC
Make sure you disable all power saving in the BIOS (including and speed switching or C states above C1)
"optimum defaults" are probably sub-optimum for real time
Also as others have mentioned, NVidia bad for real time
20 May 2019 05:09 #134325 by Mike_Eitel
Replied by Mike_Eitel on topic Latency problems on a fairly recent PC
On seldom spices: Has anybody tried difference when replacing hdd by ssd?
20 May 2019 15:04 - 20 May 2019 15:08 #134362 by petmakris
Changing to a PCI express GPU (as mentioned above) makes no difference. Still the same levels of max jitter.
I don't see how this could be relative to SMI as it does not make a difference the time vs max jitter. It's 425 micro sec on 1millisecond thread right from starting up the latency-test executable.
Also the BIOS has no such settings. I will add some screenshots.
Last edit: 20 May 2019 15:08 by petmakris.
20 May 2019 15:33 #134365 by petmakris
Time to create page: 0.483 seconds
