Lathe Z axis/joint not homing after updating to 2.8
- Hakan
- Thank you received: 454
22 May 2019 22:07 #134624
by Hakan
Replied by Hakan on topic Lathe Z axis/joint not homing after updating to 2.8
I have JOINTS=2 and COORDINATES= X Z in my lathe and that works fine. There was a change when moving to 2.8, don't remember exactly but it was along the lines that a Y axis needed to be defined but not used. In 2.8 that isn't needed anymore. Two joints refered to as JOINT_0 and JOINT_1, and AXIS_X and AXIS_Z.
- Thank you received: 2173
22 May 2019 22:11 #134625
Replied by cmorley on topic Lathe Z axis/joint not homing after updating to 2.8
try this:
Chris M
[TRAJ]
COORDINATES = X Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 2.50
MAX_LINEAR_VELOCITY = 25.00
[KINS]
KINEMATICS = trivkins coordinates=xz
JOINTS = 2Chris M
22 May 2019 22:14 #134626
Did you make this config with pncconf in 2.8 or did you convert it from 2.7?
- vmihalca
- Thank you received: 22
23 May 2019 03:48 #134658
by vmihalca
Replied by vmihalca on topic Lathe Z axis/joint not homing after updating to 2.8
I converted from 2.7, it was working fine there.
23 May 2019 04:38 #134661
Ok that makes sense - things have changed a bit in 2.8.
Changing things as above should fix it.
We probably should add an error if [JOINT] sections are missing.
Chris M
Chris M
- Thank you received: 4141
23 May 2019 04:39 #134662
CHris, I can't see that will work out of the box becasue he will have wired his lathe in 2.7 to the Z (joint2) axis so your solution puts the Z axis on a different stepgen. SO he would need to rewire.
I think lathes have been overlooked with the joint axis and if its not properly resolved this will be very wasteful of resources once more and more people move to V2.8
Replied by rodw on topic Lathe Z axis/joint not homing after updating to 2.8
try this:
[TRAJ] COORDINATES = X Z LINEAR_UNITS = mm ANGULAR_UNITS = degree DEFAULT_LINEAR_VELOCITY = 2.50 MAX_LINEAR_VELOCITY = 25.00 [KINS] KINEMATICS = trivkins coordinates=xz JOINTS = 2
Chris M
23 May 2019 04:41 #134664
Oh yes you are quite right - he will also need to change the ini and HAL file to change all [JOINT_2] to [JOINT_1]
23 May 2019 04:47 #134665
Yes I anticipate the masses converting from 2.7 to 2.8 will have some problems.
Andy's script for conversion probably covers 90% - maybe we can catch this with that.
I have also started to consider whether an INI validation would be useful/possible.
I have used a basic version of that with my panelui project.
But I good error message would have brought this in light more quickly.
But good eyes you have there Rod!
Chris M
Chris M
23 May 2019 06:39 #134667
Chris, I think what this shows is that the so called independent (joint) axes is not independent as you can't skip a nonexistent joint (as you need to on a lathe, unless its like my manual one where the DRO is marked for X & Y!
I don't know how hard it would be but perhaps the trivkins coordinates string needs another NULL item so you could do something like thisWhich would be an instruction to skip joint1
KINEMATICS = trivkins coordinates=x-zPlease Log in or Create an account to join the conversation.
- vmihalca
27 May 2019 17:20 #135074
by vmihalca
Changing joint_2 to joint_1, got the job done.
Thanks guys!
Thanks guys!
Time to create page: 0.255 seconds
